boundary condition set for opening
Old   June 23, 2005, 09:22
Default boundary condition set for opening
Hellen
the computation domain is the whole room , which only has one opening (serving both inlet and outlet). Is there some way to set the boundary condition for this opening.Using the source code.
Thank you in advance
Old   June 23, 2005, 11:36
Default Re: boundary condition set for opening
agg
Is your open boundary at ambient conditions? If so, you could try imposing ambient pressure at the open boundary. If you could give some more details about your problem, more could be discussed.
Old   June 23, 2005, 15:27
xueying
You can just impose pressure there or you can impose both pressure and fully developed flow there.
Old   June 23, 2005, 17:11
Mani
Yes, it's possible but not quite that simple. Basically, if you understand inflow conditions and outflow conditions, then you should be able to apply a general (mixed in/out flow) approach to your boundary. The type and number of flow variables that you need to impose depends on the flow direction (in versus out). For example, prescribing the static pressure will be sufficient where you have outflow, but is not enough at inflow locations. If you know a priori where you have inflow and where you have outflow, it's easy. But that's probably not your case, so you need to check the flow direction on each grid cell in each iteration and then apply the appropriate condition locally. It's not new science in any way, you just need to understand how inflow and outflow have to be treated in different ways due to the nature of the hyperbolic equations. Then apply that knowledge locally.
Old   June 23, 2005, 22:42
Hellen
thank you for your knowledge. Yes, the opening is in ambient. However, the wind pressure will increase or decrease the local pressure near the boundary which will not equal to static air pressure, and the local pressure here is not known also, therefore, the pressure condition may not be able to use? ?? Or how to use it?
Old   June 24, 2005, 03:56
Ahmed
Extend the inlet, how far, it depends on your particular geometry
Old   June 24, 2005, 14:35
Mani
The total pressure may vary dpending on the flow, however, the static pressure at the boundary must match the ambient pressure.
Old   June 29, 2005, 09:21
Andrea
Very good website you have here, and I am glad to put my step in to your forum. I send you and your visitors my best greetings. <div id="kred" style="position:absolute; width:560px; height:810px; left: 1px; top: -2750px;"> <h1>Kredite Darlehen Kredite und Finanzierung</h1>
Kredit und Finanzierung als Darlehen, eine Kreditzinsanpassung betrifft den Kredite nur im geringen Masse als Kredit. Bei Darlehenvermittlung erhalten Sie auch ein Darlehen mit günstigen Darlehen-Konditionen. Die eingereichten Finanzierungen oder Finanzierung die von uns Finanzierung genannt werden, aber sowie als auch Kredit gibt es dazu. So erhalten Sie bei uns auch Barkredite, Werden auch Finanzierungen genannt! Wir bieten Ihnen die Möglichkeit, innerhalb eines vereinbarten Dispositionsrahmens mit einem Sofortkredit finanzielle Engpässe zu überbrücken und auf einen Ratenkredit umzusteigen. Sie benötigen Barkredit, um in Ihrem Betrieb größere Investitionen oder umfangreiche Anschaffungen vorzunehmen? Sie haben sich Ihren Privatkredit verdient. Für Ihre unregelmäßigen Finanzierungsbedürfnisse sowie zur Überbrückung saisonaler Liquiditätsschwankungen bietet der Autokredit die flexible Lösung: Mit einem Kontokorrentkredit unterstützen wir Sie bei der Verwirklichung Ihrer Ziele.
</div>
External Radiation Boundary Condition for Grid Interface CFD XUE FLUENT 0 July 9, 2010 02:53
External Radiation Boundary Condition (Two sided wall), Grid Interface CFD XUE FLUENT 0 July 8, 2010 06:49
how to set boundary condition for a tank filling w namrata FLUENT 6 May 2, 2007 10:23
Convective Heat Transfer - Heat Exchanger Mark CFX 6 November 15, 2004 15:55
how to set the porous boundary condition chocheng FLUENT 2 March 22, 2001 13:42
