stream function & vorticity boundary condition
Old   December 4, 2011, 11:45
Default stream function & vorticity boundary condition
sara
sara2115 is on a distinguished road
HI everyone.
I've wrote a code to simulate velocity field over a square cylinder.
I've used vorticity-stream function solver at 0 angle of attack.(not immersed)
but now I don't know how to specify outflow boundary condition for different angles of attack.
I used a rectangular as my domain.
please help me.
thank you for reading my thread.
sara2115 is offline   Reply With Quote
Old   December 5, 2011, 09:10
Andrew
mettler is on a distinguished road
I did this for a finite difference method (except I did flow over a step). My exit boundary condition was @x=L, Streamfunction(@x=L) = Streamfunction(@x=L-1). I did this based on assuming that the flow after the step was fully developed and not changing. My vorticity BC was the same. The results were good.
mettler is offline   Reply With Quote
Old   December 6, 2011, 10:53
sara
Thank you for your reply Mettler.
but in my case I have vortex shedding which makes it more complicated.
By the way, did free stream velocity have an angle of attack in your case? or it was simply horizontal?
Old   December 6, 2011, 11:08
Andrew
it had no angle of attack, but why can't you extend the rectangular grid long enough to where the vortex shedding has dissipated and the flow is fully developed?
Old   December 7, 2011, 17:42
sara
Dear Mettler.
Well, I did so.
but still there are lot's of problems.
for example, even if the flow behind the cylinder is fully developed, it still has its angle of attack, so I can't impose the boundary condition you used for outflow.
there are other difficulties in dealing with far field boundaries.
thank you for your reply.
[Other] mesh airfoil NACA0012 anand_30 OpenFOAM Meshing & Mesh Conversion 13 March 7, 2022 17:22
[blockMesh] BlockMesh FOAM warning gaottino OpenFOAM Meshing & Mesh Conversion 7 July 19, 2010 14:11
vorticity stream function method ztdep Main CFD Forum 0 April 15, 2010 10:17
How to apply a function as boundary condition coompressor OpenFOAM Running, Solving & CFD 0 January 13, 2009 03:50
[blockMesh] Axisymmetrical mesh Rasmus Gjesing (Gjesing) OpenFOAM Meshing & Mesh Conversion 10 April 2, 2007 14:00
