How to extract surface from plot3d grid (NASA chimera mesh)
Old   December 8, 2011, 01:11
Default How to extract surface from plot3d grid (NASA chimera mesh)
Rohan V. Kedare
kedarerohan is on a distinguished road
Can anybody tell me how to extract surface from plot3d mesh. Insist me some software that reads plot3d format grid.
I have taken mesh from nasa website of space shuttle launch vehicle. Its an chimera grid in plot3d format. This mesh doesnot open in Ansys ICEM. What is the reason. If not can can i extract surface from this grid, so that i can make my own mesh.
kedarerohan is offline   Reply With Quote
Old   December 11, 2011, 16:39
John Chawner
jchawner is on a distinguished road
Rohan:
I'm surprised that ANSYS ICEM can't read a PLOT3D file. My suggestion is to verify the PLOT3D file's format and ensure you're giving ICEM the correct options.
PLOT3D is a widely used de facto standard format for structured grids. You can see the format spec here: http://www.grc.nasa.gov/WWW/wind/valid/plot3d.html. Perhaps you could write your own code to extract the surfaces if you can get ICEM to work.
But I repeat: I'd be shocked if ICEM couldn't read that file.
Best Regards
John Chawner / jrc@pointwise.com / www.pointwise.com
Blog: http://blog.pointwise.com/
on Twitter: @jchawner
jchawner is offline   Reply With Quote
Old   December 12, 2011, 00:23
Rohan V. Kedare
Sir, Actually I have found that it is an Chimera mesh (overlapping type), thats why ICEM could not read the mesh. I am not a software person, cant write a code. Can you suggest me any software so that I can extract surface from that mesh, and create my own mesh.
Old   December 12, 2011, 09:16
John Chawner
Rohan: Have you tried email the custodian of the web page from which you downloaded the file to see if they have some suggestions?
Old   December 13, 2011, 01:23
Martin Hegedus
Martin Hegedus is on a distinguished road
I assume you mean the shuttle grid from http://www.nas.nasa.gov/Resources/datasets.html Those files are in big-endian format so, if you are using an intel box, the program that reads in the file will need to realize this and switch it to little-endian.
Martin Hegedus is offline   Reply With Quote
Old   December 13, 2011, 02:25
Joern Beilke
JBeilke is on a distinguished road
Just rename the grid file to grid.xyz and read it with EnSight or Paraview.
The data are in PLOT3D, multiple-zone, iblank, binary. All floating point data are in 32-bit IEEE format, big endian.
JBeilke is offline   Reply With Quote
how to set periodic boundary conditions Ganesh FLUENT 15 November 18, 2020 06:09
[ICEM] surface mesh merging problem everest ANSYS Meshing & Geometry 44 April 14, 2016 06:41
[ICEM] Automatic mesh generation script surface intersection problem stuart23 ANSYS Meshing & Geometry 0 May 13, 2011 01:10
[Other] Surface aligned mesh rpasiok OpenFOAM Meshing & Mesh Conversion 6 January 7, 2008 05:55
CFX4.3 -build analysis form Chie Min CFX 5 July 12, 2001 23:19
