pl. HELP: Convert TVD scheme from NV formulation
Dear friends
I work on implementation of high-order and TVD schemes for convective terms. I found some literature, but have faced with a problem: In the most issues was used formulation of schemes in normalized variables. For program implementation I need a formulation in usual variables with distinguishing of first-order upwind part and other part, which will go to the source term. Any suggestions will be highly appreciated Thanks in advance Mike |
NV FORMULATION vs. NVSF FORMULATIOIN
Does anybody know, how better high resolution schemes in NVSF?
I used QUICK and HLPA and on non-orthogonal non-uniformed grids and rather succesfully. I found an article with NVSF formulation of high oder schemes and thinking now, will it worth to use NVSF? |
Re: NV FORMULATION vs. NVSF FORMULATIOIN
In my experiqance the HLPA scheme is best for many incompresible flow calculations. The SMART scheme shows an oscillation problem in a certain problem. Can you show me the article you have read? You know that the NVF by Gaskel and Lau is applicable to the scheme lower than 3-order accuracy.
I have send the articles to You.
I also find HLPA scheme the best for incompressible flow caculations and fond of it. But I am going to implement others schemes and try it on Smith-Hutton task. If You have good descrition of HLPA, won't it be difficult for You to send it to me? (I have, but it rather restricted). Best wishes Mike |
please article by Zhu J. (HLPA scheme)
Dear colleagues, please if anybody can, send me an article by Zhu J.
if I was in St.Petersburg, I would go to the library, but unfortunately I can not. I shall be very grateful. --------------------------------------------------------------------------- Zhu J. "On the higher-oder bounded discretization schemes for finite-volume computations of incompressible flows" // Computational Methods in Applied Mechanics and Engineering. 1992. 98. 345-360 or/and Zhu J. "Low-diffusive and oscillation-free convection scheme" // Communications and Applied Numerical Methods. 1991. 7, N.3 225-232 or/and Zhu J. Rodi W. "A low dispersion and bounded discretization schemes for finite volume computations of incompressible flows" // Computational Methods for Applied Mechanics and Engineering |
Re: please article by Zhu J. (HLPA scheme)
If you give me your address by email or post it here, I will send the articles to you. I do not have electronic files for them.
Good luck |
Dear Halim, thanks a lot for Your help
here is my Email (use it) michailkirichkov@yahoo.com.au also there I found some reviews: www.tfd.chalmers.se/~lada/ postscript_files/numer_methods_zhou.pdf http://citeseer.ist.psu.edu/zijlema95higher.html (download PS.gz) www.simuserve.com/support/docs/numerics/schemes.doc again thank You very much |
Dear Dr. Seok-Ki Choi, thank You very much
I have got the papers, thank You very much. I can not express my gratitude to You for Your help. You are very generous, that DHL post I guess, was very expensive. Excuse me for my offer (about beer), it was rather impolite from my side, but I did not know that You are Doctor of Science. Again Thanks a lot for You help. Respectfully Yours Michail |
