March 25, 2012, 14:46 |
problem about uniting some volumes
light
Greetings,
Well, I'm new here and also to CFD.. My final project is using CFD... Imagine that a cylinder (pipe) has a bend 90 degree... and I'm supposed to put 4 small cylinders into the big cylinder(pipe)... If we cut the pipe the cross section area would be a circle... so the position of the 4 small cylinders would be at the top, bottom, left, and right at the arc of the circle. the problem is the uniting process is successfully done for the 2 cylinder which is at left and right..but it turns disappointing when I'm trying to unite the top an bottom..I hope the readers are understand since the problem might be blurry to you..thank you.. |
Display Modes | |
problem importing mesh into gambit | tsm554 | FLUENT | 7 | December 3, 2010 23:15 |
Can I solve this problem by Fluent? | Kai_kc | FLUENT | 1 | October 27, 2010 06:29 |
Adiabatic and Rotating wall (Convection problem) | ParodDav | CFX | 5 | April 29, 2007 20:13 |
gambit error uniting two volumes | Ralf Schmidt | FLUENT | 3 | January 30, 2006 09:51 |
problem in CFX solver about isolated volumes | Yuan | CFX | 2 | August 16, 2004 23:54 |
