August 7, 2005, 02:40 |
Interface Tracking
Where may I download a reliable 2d FORTRAN (axisymmetric) front tracking code? Any help in this regards is highly appreciated.
August 7, 2005, 11:59 |
Re: Interface Tracking
Hi
There are many methods to track the front. On which method based code do you need. |
August 8, 2005, 01:14 |
Hi! Vinod, No big difference. However, I prefer Front Tracking Method of Glimm et al. For your information, I have a high pressure gas which expands in air. I need to track the interface in an axisymmetric space.
August 8, 2005, 09:24 |
Hi
I can send you a code, which is F77 bsed, and 2-dimensional. The code is not very well written and documented, but gives right answers. You can't use Intel's Fortran or g77 for compiling this code. Either use MS Fortran or Compaq's Fortran, which I use. I'm writing my own F90 code, and after it gets completed I'll put it on net. That's will better than this. Both of these codes use Level Set Method. If you need any help, you can write to me, or post message. Vinod Dhiman |
August 10, 2005, 07:30 |
Hi Vinod,
I would be great if you put the Level Set Mwethod code on the web as it would be interesting to see how you implemented it. I am a little dubious about how different people do this. Where will you post them? Thanks. |
August 10, 2005, 11:50 |
Thanks for your interest in this. I'm glad to know that people know about it, and want to work in the field.
Right now I can't put it on the net. Since it is not written by and I don't have permission to put it on the net. I'm writing my own code, which is better than this one, and includes phase transfer, too. As soon as I complete my code, I'll put it on the net. I'll post a message regarding this. Vinod Dhiman |
Wind turbine simulation | Saturn | CFX | 58 | July 3, 2020 01:13 |
RPM in Wind Turbine | Pankaj | CFX | 9 | November 23, 2009 04:05 |
what is Interface tracking? | gholamghar | Main CFD Forum | 1 | March 18, 2009 05:58 |
Convective Heat Transfer - Heat Exchanger | Mark | CFX | 6 | November 15, 2004 15:55 |
Replace periodic by inlet-outlet pair | lego | CFX | 3 | November 5, 2002 20:09 |
