NACA standart roughness
Old   August 23, 2005, 01:59
Default NACA standart roughness
DAK565656
Hello! I have a question about NACA (NASA) standart roughness on airfoils (in form of strip). I read, that this roughness is used to initiate boundary layer transition from laminar flow to turbuluent flow. In addition, the form and location of roughness is chosen in way, that minimize drag force (or drag coefficient). NACA published results, where both plots for smooth and with roughness surface are illustrated. Please explain me, for what do NASA researchers use roughness strip? Why do they try to initiate boundary layer transition? And how does roughness strip corresponds to turbulence models, which are used in finite-element software (such as star-cd and ansys). I have some results obtained from this software and don't know which plot (smooth of roughness) should be used to check these results.
Old   August 23, 2005, 08:57
Default Re: NACA standart roughness
Jim_Park
You have several questions there. To try and answer one of them,
the roughness strip is used to 'trip' the boundary layer from laminar to turbulent because a turbulent boundary layer will remain attached to the surface for a longer distance, allowing more lift to be generated on a particular wing at a particular flight speed.
Generally a 'separated boundary layer' (contradiction but standard language!) results in a bubble of reverse flow above the separation point that destroys lift generation.
Old   August 24, 2005, 00:47
DAK565656
Thanks for answer. I have already answered my questions by myself
nutRoughWallFunction and Surface Roughness Documented AlanR OpenFOAM Programming & Development 64 January 6, 2024 07:13
Laminar flow and wall roughness junbbung FLUENT 2 November 26, 2022 21:22
Roughness adaptation in CFX 4.4 Bart CFX 1 May 2, 2003 08:32
Roughness for NACA 23012 ??? Raph FLUENT 1 December 31, 2002 11:47
roughness of NACA 23012 Guillaume Duminy Main CFD Forum 0 December 30, 2002 09:39
