Pressure Losses
Old   March 6, 2012, 02:48
Cool Pressure Losses
Ettore
Edy85 is on a distinguished road
Send a message via MSN to Edy85
Good day, I have a big problem
I want to calculate the pressure losses in a divergent pipe; the start diameter is about 400 mm whereas at the end it is 500 mm. This increment takes place in about 1 meter of pipe lenght (no vortices are generated).
I run the 2D simulation in FLUENT v13 (velocity outflow: 1m/s; pressure inflow: 10 bar) and the residuals convergence is really good (more than 10^-6).
PROBLEM: I calculate the TOTAL PRESSURE with the function areaAve on the inlet section and on the outlet one. The incredible result is that the Total Pressure is increased (of about 250 Pa)!!! I think that it's not possible. It happens with a spatial discretisation of the second and of the third order, both with a k-eps and Reynolds stress model.
Do you have any suggestions??
Edy85 is offline   Reply With Quote
fluent, pressure, pressure drop, pressure losses
Pressure Inlet VS velocity Inlet difference Mohsin FLUENT 9 January 4, 2021 10:34
influence of specified density in head losses or static pressure Tres FLUENT 1 November 23, 2011 04:54
head losses or static pressure Tres Main CFD Forum 7 November 22, 2011 11:51
Pressure losses for compressible flows chouki FLUENT 0 November 21, 2008 03:47
pressure losses Olivier Macchion CFX 5 December 13, 2002 04:43
