September 6, 2005, 09:35 |
grids in tip clearance
hi,everyone.
my model is a axial pump,and the tip clearance is very short to the whole radius. and i met a problem for grids. when i make ogrids for blade,i don't know where to put the ogrids vertices between the shroud and blade tip. and some grids are always wrong with small angel ,such as 0-9 degree. how to avoid this situation? thank you very much! |
September 8, 2005, 16:17 |
Re: grids in tip clearance
Do you really need a grid in the tip clearance? Most of the time a tip clearance model is quite sufficient, avoiding the trouble to create a grid in that region. If you really want to grid it, you will need a more complex multiblock topology (assuming you are using structured grids), to get a grid of good quality.
September 12, 2005, 00:50 |
thank you very much! i have finished the structrued grids
[ICEM] Turbine blade with filleting and tip clearance | Pursuor | ANSYS Meshing & Geometry | 4 | July 7, 2010 13:56 |
Meshing in tip clearance. | me | Siemens | 0 | August 25, 2008 03:20 |
grids between tip clearance | iceraining | CFX | 2 | September 7, 2005 08:11 |
Tip Clearance | Liam | CFX | 3 | September 7, 2005 05:30 |
Tip Clearance | Drona | CFX | 0 | October 17, 2002 05:25 |
