Orr Sommerfeld equation
Old   March 18, 2012, 01:12
Default Orr Sommerfeld equation
Aniket Sachdeva
thegodfather is on a distinguished road
My question is very fundamental.
why, at all do we need to have a separate equation that predicts the growth or decay of perturbations in a steady base flow..? If at all, there are any perturbations in the flow, why can't the resultant motion of fluid be predicted using the usual Navier Stokes equations??
thegodfather is offline   Reply With Quote
Old   March 18, 2012, 04:27
truffaldino's Avatar
truffaldino is on a distinguished road
Because Navier-Stokes equation is too complicated to be solved analytically. This is the main problem of all fluid dynamics. That is why we still know almost nothing exact about turbulence.
truffaldino is offline   Reply With Quote
Old   March 18, 2012, 06:43
Aniket Sachdeva
thanks a lot for replying... but as far as i know, even Orr - Sommerfeld equation is a fourth order linear differential equation which cannot be solved analytically for most cases, and various numerical methods have to be resorted to solve it... In that case would it not be better to bear with a little more complexity in terms of better numerical methods and solve the full N-S equations?
Old   March 18, 2012, 06:57
As you said Orr-Sommerfeld is a linear system, while Navier-Stokes is nonlinear and shows chaotic behavior (turbulence) which is difficult analyse even numerically (DNS is done on supercomputers).
In the case of Orr-Somerfeld you have a possibility of qualitative analysys of transition to turbulence. You can see how perturbations amplify etc.
Old   March 18, 2012, 07:04
Aniket Sachdeva
thanks.. that was really helpful..
mass flow in is not equal to mass flow out saii CFX 12 March 19, 2018 05:21
Calculation of the Governing Equations Mihail CFX 7 September 7, 2014 06:27
Constant velocity of the material Sas CFX 15 July 13, 2010 08:56
Orr Sommerfeld on Airfoils Mojtaba Main CFD Forum 0 October 1, 2008 15:40
Orr Sommerfeld equation Mojtaba Ahmadi Main CFD Forum 2 September 9, 2008 05:00
