August 26, 2005, 04:14 |
Cd value for square cylinder
hello ppl
please help me....for a square cylinder(2D) the drag coefficient value comes to 2.1 . In the figure given below if i increase "L" and keep the "D" constant what will happen to the Cd value???? this is a 2D case. L ---------- | | | | ------> | | D | | | | ---------- any help is highly appreciated.. thanks in advance.... regards karthik |
August 26, 2005, 05:07 |
Re: Cd value for square cylinder
Do you mean how the Cd value will change from square cylinder (L=D) to rectangular cylinder (L=length, D=width) ? If so, then the following reference might be of your interest
S. Nitin and R.P. Chhabra, "Non-isothermal flow of a power law fluid past a rectangular obstacle (of aspect ratio 1 Ã- 2) in a channel: Drag and heat transfer", International Journal of Engineering Science, Volume 43, Issues 8-9, May 2005, Pages 707-720 There you can find data table for drag (table 1) and Nusselt number (table 2) for Re=5-40 at n=1 (newtonian fluids). Regards, ramp |
September 20, 2005, 15:20 |
hey karthik,
the cd value for Re=10 is aroung 8. that i have seen in one thessis. i have added u in googletalk. my name is swadeshkumar. ok? don |
September 21, 2005, 05:01 |
The Cd valud for unconfined flow past square cylinder at Re=10 is 4.063 (see Nitin and Chhabra, Int J Engineering Science, 43, pp 707-720, 2005).
For confined flow (blockage ratio: 1/8), Cd is 3.63 at Re=10 (see Dhiman et al., Int J Heat Mass Transfer, 48, 2005, Pages 4598-4614) Hey don, please check the thesis and these papers. Best regards, ramp |
benchmark: flow over a circular cylinder | goodegg | Main CFD Forum | 12 | January 22, 2013 11:47 |
Incorrect Drag and Drag Coefficient for flow over a cylinder | ozzythewise | Main CFD Forum | 8 | June 13, 2012 06:24 |
[blockMesh] Specifying boundary faces failes in blockMesh | blaise | OpenFOAM Meshing & Mesh Conversion | 0 | May 10, 2010 03:56 |
rotating cylinder using sliding mesh | Tim Daly | FLUENT | 1 | November 9, 2008 23:02 |
Turbulent steady flow around a circular cylinder | Mirek Kabacinski | FLUENT | 0 | July 23, 2003 18:40 |
