High Reynolds Free Surface Flows
Old   September 16, 2005, 17:13
Default High Reynolds Free Surface Flows
Ferreira
Hi Dear Friends,
Nowadays, I am working in the numerical simulation of High Reynolds Free Surface Flows. My code is in 3D finite diference primitive variables. My question is this: In order to validate my computer code, there is some analytical solution for this class of fluid flow?
Best Regards Ferreira
Old   September 17, 2005, 19:19
Default Re: High Reynolds Free Surface Flows
Scott Shaw
If you can't find an anlytical solution why not consider making one up and using the method of manufactured solutions to verify your code ?
Scott
Old   September 18, 2005, 02:29
M
You can find an analytic solution using perturbation methods. Refer to Van Dyke's "Perturbation Methods in Fluid Dynamics."
Old   September 28, 2005, 02:45
Mark Carlson
You can measure the period and height of the surface oscillations after a drop in a pool. The height and time of the apex is known.
Post Processing free surface flows Chris Wetton CFX 2 February 14, 2008 08:14
Multiphase flow. Dispersed and free surface model Luis CFX 8 May 29, 2007 18:13
depths in a two phase free surface flows scott copland FLUENT 0 March 7, 2007 10:22
Free surface flows Wilhelm Brandstaetter Main CFD Forum 2 July 20, 2000 17:21
Modeling Free Surface Flows Elliot Schwartz Main CFD Forum 5 August 25, 1998 21:03
