channel flow question
Old   April 28, 2008, 16:11
Default channel flow question
keith
Hi everyone,
I am currently trying to verify my finite volume code with the a channel flow problem(Re_tau=180). My question is regarding the setup of the problem.
I prescribed a constant pressure gradient to drive the flow. Do I also prescribe the wall shear stress value(Tau_w) or should I just set the wall boundary condition as no slip?
Please help me as I am still a little confused.
Old   April 29, 2008, 09:21
Default Re: channel flow question
otd
no-slip
Old   April 29, 2008, 10:25
keith
otd,
thanks for the quick reply. If the wall boundary was set to no-slip(no wall shear prescribed), how does the program know the "roughness" of the channel?
Old   April 29, 2008, 20:26
otd
I don't know. It has to depend on what you've built into the code. So it's a modeling question - and, if it's your code, you're the modeler.
Old   September 13, 2012, 05:42
Default wall SHear stress in cahnnel flow
ronak
MD276 is on a distinguished road
Originally Posted by keith
;54939
Hi everyone,
Hi ,I m also work with some DNS data IN RE-taw=180.
I have 130*130*130* grid point in 5 timewindows.
The pressure Gradient is 1.I try to find Taw-Av on the wall. it should be near 1, but My simulation give me a wrong value.
I USED THIS statement for TAW.
IS IT POSSIBLE TO HELP ME?
taw(i,k,n)=(U(i,1,k,n)-U(i,1,0,n))/(yc(1)-yc(0))
I OBTAIN the diffrence of u at each grid for J=0 AND 1
MD276 is offline   Reply With Quote
Old   September 14, 2012, 05:14
Filippo Maria Denaro
FMDenaro has a spectacular aura aboutFMDenaro has a spectacular aura aboutFMDenaro has a spectacular aura about
if you fix the pressure gradient then the tau wall will be not necessarily exact ... some percent of difference is acceptable.
FMDenaro is offline   Reply With Quote
Boundary condition problem for open channel flow Andy CFX 9 June 11, 2016 07:20
VOF modelling open channel river flow Matthew Roberts FLUENT 6 July 31, 2009 12:52
pressure outlet (open channel flow) Willem Brantegem FLUENT 2 April 4, 2007 02:40
Flow Split Setup Question ed FLUENT 1 February 16, 2007 16:55
compressible channel flow.. R.D.Prabhu Main CFD Forum 0 July 17, 1998 17:23
