April 15, 2012, 14:40 |
Boundary layer separation
Aniket Sachdeva
It is said that a boundary layer separates from the surface when the inertia of the fluid is not enough to counter the viscous and pressure forces...
But increasing the flow speed will increase the tendency of the boundary layer to separate... Does that not mean that higher inertia in the fluid will make the boundary layer more susceptible to separation.. whereas from definition of separation it is clear that lower inertia should be responsible for flow separation..? |
April 16, 2012, 04:02 |
April 16, 2012, 06:43 |
Aniket Sachdeva
For example in the case of flow past a cylinder or a sphere, a low speed fluid stream will follow the curvature and will remain attached to it.. But increasing the speed will lead to separation... Isn't it a paradox??
April 16, 2012, 11:07 |
You are talking about very low reynolds number regime for highly curved objects where boundary layer approximation does not work: For cylnders and spheres the flow remains stationary only for reynolds number up to order 10^1-10^2, which means that the boundary layer size is of order of the object size, i.e. bl does not really exist. For higher reynolds numbers the flow past such objects becomes nonstationary, the vortex shedding occurs and bl theory does not really work too.
The bl layer theory works for high reynods numbers and mild adverse pressure gradients, e.g. for flows past airfoils in which case higher speed means later separation. |
April 16, 2012, 12:03 |
Aniket Sachdeva
Thanks for replying
I did not understand, what is the meaning of boundary layer size being of the order of the object size.. n how does low value of reynolds numbr imply the same..? |
April 16, 2012, 12:33 |
#6 | |
ratio of the boundary layer thikness to the object size is of order 1/sqrt(Re). In the case of spere or cylinder the flow is stationary up to Re of order 10^1-10^2. This means that bl size is about 1/3 to 1/10 of the object size, which is not really the boundary layer. In the boundary layer theory the pressure does not change across the layer in direction normal to the surface, while it gradually changes along the direction parallel to the surface on the scale which is much greater than bl thikness. All this does not make sence when your bl thikness is 1/3 of the object curvature and Prandtl argumentation about decelleration of different parts of bl prior to separation simply does not work. |
April 17, 2012, 02:56 |
Aniket Sachdeva
Then, is there any other theory to predict flow separation for such cases...?
(i.e. other than Boundary layer approximation) |
April 17, 2012, 04:16 |
I am not a specialist in this field, but what I have seen on this topic are only numerical simulation. BTW for very low speed regime numerical simulations are quite easy and reliable, since turbulence modelling is not involved.
April 17, 2012, 07:21 |
#9 | |||
Lucky
Rep Power: 65 |
For simple flows, there are engineering correlations for when and where a flow will separate and there are some models for how to treat the laminar to turbulent transition zone. The canonical example is the flat plate boundary layer. In general, transitional turbulence is a mess to deal with. Last edited by LuckyTran; April 18, 2012 at 02:32. |
April 17, 2012, 08:54 |
Aniket Sachdeva
Thanks truffaldino for clearing my doubt...
N thanks LuckyTran for deepening my understanding about the topic... |
Wind turbine simulation | Saturn | CFX | 58 | July 3, 2020 01:13 |
Domain Imbalance | HMR | CFX | 5 | October 10, 2016 05:57 |
CREATION OF BOUNDARY LAYER | Jibran Haider | FLUENT | 3 | August 1, 2008 00:33 |
New topic on same subject - Flow around race car | Tudor Miron | CFX | 15 | April 2, 2004 06:18 |
