How could i improve an aircraft design using CFD? |
April 22, 2012, 09:06 |
Rep Power: 16 |
I have designed an aircraft studying Raymer's book. How could i improve this design using the 3d aircraft model and a CFD package? Any ideas? Thanks a lot!! |
April 22, 2012, 09:11 |
#2 | |
Rep Power: 14 |
Regards |
April 22, 2012, 09:19 |
Rep Power: 16 |
Thanks for the answer!
My question is how i could improve the design, studying the 3d aircraft geometry numerically with a CFD program! For example studying the cp distribution along the wing, would be useful in order to improve the desing? Any ideas about the results that i could take using CFD and would help me to improve aircraft design? |
April 22, 2012, 09:45 |
Aniket Sachdeva
Rep Power: 14 |
U can definitely improve your design if you have a good cfd software and the required computing power at your disposal...
You can improve your wing design by simulating flow over the wing designed by you and changing some parameters like chord, span, nose radius etc. n study its effect on the lift-drag characteristics... |
April 22, 2012, 10:31 |
Rep Power: 16 |
Thanks thegodfather!
I have studied lift-drag characteristics changing some parameters like chord, spn, etc using xfoil and profili! Using CFD program like fluent, i will have more accurate results? |
April 22, 2012, 12:57 |
Aniket Sachdeva
Rep Power: 14 |
I am afraid I may not be the best person to answer this question...
I am just about to enter my senior year in mechanical engineering and have just started learning various numerical schemes to understand fluid motion... I do not have a lot of experience in using cfd softwares... The idea of improving the design using cfd seemed just too appealing not to be given at least a try.. All the best... N do post if u succeed in improving it.. |
April 22, 2012, 15:15 |
Filippo Maria Denaro
Rep Power: 71 |
normally, the "optimization" techniques are used along with CFD softwares ... Cp, Cd, as well as other parameters can be used as target.
April 22, 2012, 16:33 |
#8 | |
As an example you can take a look at comparison of results by x-foil and Large Eddy Simulation at this link http://persson.berkeley.edu/pub/uranga09iles.pdf The results have the same accuracy for LES and x-foil, while, in the above case, LES will run for weeks on ordinary computer, while x-foil will do it in a fraction of second. Truffaldino |
April 23, 2012, 02:06 |
#9 |
Joern Beilke
Rep Power: 20 |
Future CFD Research | Jas | Main CFD Forum | 10 | March 30, 2013 12:26 |
CFD inverse design | chitharenjan | Main CFD Forum | 0 | August 13, 2010 08:38 |
CFD for fans & blower housings | David Carroll | Main CFD Forum | 8 | August 24, 2000 17:25 |
Evaluation for CFD software purchase | Nasim Suleman | Main CFD Forum | 3 | July 24, 2000 11:15 |
part-time-cfd | Michael | Main CFD Forum | 6 | February 2, 2000 12:01 |
