Home > Forums > Special Topics > Mesh Generation & Pre-Processing
ICEM turbine meshing issues
Old   January 30, 2015, 04:15
Default ICEM turbine meshing issues
spl
spl
spl is on a distinguished road
Hi guys
I am currently meshing a radial turbine stage (wheel, volute and outlet) in ICEM. I follow what i believe is the correct steps to achieve a good mesh (from Simon Pereira's Tips and Tricks presentation). However after the mesh is complete the min angle is less than 9deg and the mesh expansion factor is very high. Smoothing the mesh further only makes this worse and trying to adjust each cell by hand isn't an option as there are 10,000 cells with min angles less than 9deg. These 10,000 cells only make up about 0.04% of the mesh though.
So my question is are bad cells acceptable if their overall percentage is kept so low? Or has anyone got experience in meshing radial turbines in ICEM and know how to avoid these issues? The worse areas tend to be between the blade edge and shroud.
Thanks in advance.
spl is offline   Reply With Quote
TurboGrid & ICEM: Turbine and wake mesh. Kaelon ANSYS 3 June 16, 2015 11:50
[ICEM] Meshing a 2D Goldman Annular Turbine Blade in ICEM ergometer ANSYS Meshing & Geometry 4 March 30, 2012 22:34
[ICEM] 2d Aerofoil meshing in ansys ICEM syler3321 ANSYS Meshing & Geometry 2 February 3, 2012 01:59
[ICEM] Need help in ICEM CFD Mapped Meshing falconf16 ANSYS Meshing & Geometry 3 February 19, 2010 14:21
Q: how to do a good meshing in turbine usin gambit oscar FLOW-3D 1 March 14, 2009 23:15
