Home > Forums > Special Topics > Mesh Generation & Pre-Processing
makeAxialMesh error.
Old   August 5, 2015, 07:53
Default makeAxialMesh error.
Marco Bernardes
masb is on a distinguished road
I'm trying to create a axissymetric mesh using the makeAxialMesh command. I'm getting the following message:
--> FOAM FATAL ERROR:
Symmetry plane 'center' is not planar.
At local face at (0 996.212 25) the normal (0 0 0) differs from the average normal (-0.20202 0 0) by 0.0408122
Either split the patch into planar parts or use the symmetry patch type
From function symmetryPlanePolyPatch::n()
in file meshes/polyMesh/polyPatches/constraint/symmetryPlane/symmetryPlanePolyPatch.C at line 64.
FOAM exiting
The fact remains that a surface which is clearly planar (defined by points with same z-values) is classified as non-planar. I have changed the patch type to symmetry but the problem persists. Any help is appreciated.
Thanks,
Marco.
masb is offline   Reply With Quote
[OpenFOAM.org] compile error in dynamicMesh and thermophysicalModels libraries NickG OpenFOAM Installation 3 December 30, 2019 00:21
[blockMesh] blockMesh with double grading. spwater OpenFOAM Meshing & Mesh Conversion 92 January 12, 2019 09:00
[swak4Foam] GroovyBC the dynamic cousin of funkySetFields that lives on the suburb of the mesh gschaider OpenFOAM Community Contributions 300 October 29, 2014 18:00
OpenFOAM without MPI kokizzu OpenFOAM Installation 4 May 26, 2014 09:17
DecomposePar links against liblamso0 with OpenMPI jens_klostermann OpenFOAM Bugs 11 June 28, 2007 17:51
