making geometry in Salome so that meshing is optimal |
April 2, 2019, 08:29 |
Rene Hiemstra
Rep Power: 9 |
Hello all,
I'm new to geometry and mesh generation. I'm trying to make a simple tank with airflow into the tank on the bottom and outflow on the top. However because i'm trying to replicate a real object the outflow should consist of 4 separate pipes. How could I arrange the faces in Salome so that my mesh is of a good quality? Included is a picture of the top of the tank, with the location of the four exits on top. Is there a way create a good mesh with this kind of geometry? If this is not possible, or very hard. What would be a good substitution? Previously I had one cylindrical face on top of a smooth cylinder, this however gave a very skewed mesh. The plan is to run the simulation in openFoam eventually. |
geometery, meshing 3d, openfoam, salome, salome meshing |
python script to create geometry for salome, and then mesh | 6863523 | Mesh Generation & Pre-Processing | 4 | March 18, 2017 09:00 |
[Other] How to use finite area method in official OpenFOAM 2.2.0? | Detian Liu | OpenFOAM Meshing & Mesh Conversion | 4 | November 3, 2015 03:04 |
[foam-extend.org] problem when installing foam-extend-1.6 | Thomas pan | OpenFOAM Installation | 7 | September 9, 2015 21:53 |
Problem compiling a custom Lagrangian library | brbbhatti | OpenFOAM Programming & Development | 2 | July 7, 2014 11:32 |
Reg difficulties in meshing the geometry...Urgent | arunraj | ANSYS Meshing & Geometry | 0 | August 26, 2011 23:25 |
