Home > Forums > Special Topics > Mesh Generation & Pre-Processing
Elliptic grid over airfoil
Old   October 26, 2015, 12:27
Default Elliptic grid over airfoil
mechiebud
mechiebud is on a distinguished road
Hello
I am trying to generate elliptic grid over an airfoil. But my grids are moving away from the boundary as I increase the iterations.any.Can some give any idea. why?
mechiebud is offline   Reply With Quote
Old   November 10, 2015, 15:55
DarylMusashi's Avatar
Holger Dietrich
DarylMusashi is on a distinguished road
Which computer language do you use? Which grid-type do you use, I suppose C-grid? The nodes at the branch cut need to be able to float (if you dont know what branch cut means: http://jullio.pe.kr/fluent6.1/help/html/ug/img318.gif).
The grid nodes, which describe the geometry of the airfoil and the outer domain must not be able to float, on the other hand. If all layers of B1 (from i=1, n) are able to float this could be the reason why the first mesh line (which describes the geometry) moves during iterations. Let the layers of B1 be able to float only from i=2, n.
B1, B2 = are not allowed to float
B3, B4 = able to float
DarylMusashi is offline   Reply With Quote
Old   November 11, 2015, 01:54
mechiebud
Thanks Daryl for the response. The problem is resolved.
Problem with airfoil shape optimization robyTKD SU2 Shape Design 7 March 7, 2022 16:18
Elliptic and hyperbolic grid generation mechiebud Main CFD Forum 0 October 21, 2015 10:14
Elliptic grid generation mechiebud Main CFD Forum 0 October 18, 2015 02:10
Problem with restart solution in shape_optimization.py robyTKD SU2 Shape Design 21 May 29, 2013 09:26
elliptic grid generation prapanj Main CFD Forum 1 November 19, 2007 16:53
