Mesh resolution for modeling flow in a porous media |
September 14, 2016, 16:12 |
Hi
I am doing some work with microfluidic channel and I want to have a much better understanding of how pore voids are filled due to the capillary pumps. As a result I want to actually model the geometry rather than using a global average of the porous zone. I have access to a HPC cluster to run this problem, but I need to get a geometry first. I have access to openfoam, CFX and FLUENT as solvers. My questions are the following 1) Is there a way to programmatically generate the geometry. I am thinking i want the ability to specify a average size and a SD and have it build a structure that has a normal distribution so I can play with different configurations quickly. 2) Once I have said structure, how many mesh elements do I need in each pore, Say I have a pore size of 3 microns. My mesh must be how many times smaller than that. The channel dimension of the channel is small obviously (140um x 3000um x 3cm) but obviously the more elements the bigger the cpu demand. Any ideas? Thanks in advance. |
Multiphase flow in porous media and relative permeabilities | sirpolar | Fluent Multiphase | 1 | July 24, 2016 05:41 |
How to model granular flow through porous media | Axius | FLUENT | 2 | August 7, 2014 10:34 |
Porous Media coupled with internal flow | Samuel Andrade | FLUENT | 2 | August 26, 2012 09:43 |
compressible flow through porous media | Chirag2302 | FLUENT | 0 | March 2, 2012 23:13 |
Question for modelling flow in porous media | legendyxg | FLUENT | 9 | April 21, 2009 22:24 |
