skewFaces Errors after snappyHexMesh
1 Attachment(s)
Hey guys,
I have included a .stl-File and want to create a mash. So I used surfaceFeatureExtract, BlockMesh and snappyHexMesh. When I tryed "checkMesh", the answer was: Create time Create polyMesh for time = 0 Time = 0 Mesh stats points: 3585719 faces: 10022446 internal faces: 9352200 cells: 3221166 faces per cell: 6.01479 boundary patches: 7 point zones: 0 face zones: 0 cell zones: 0 Overall number of cells of each type: hexahedra: 2987288 prisms: 161904 wedges: 0 pyramids: 0 tet wedges: 0 tetrahedra: 0 polyhedra: 71974 Breakdown of polyhedra by number of faces: faces number of cells 5 464 6 3624 9 65770 12 2112 15 4 Checking topology... Boundary definition OK. Cell to face addressing OK. Point usage OK. Upper triangular ordering OK. Face vertices OK. Number of regions: 1 (OK). Checking patch topology for multiply connected surfaces... Patch Faces Points Surface topology inlet 1040 1134 ok (non-closed singly connected) outlet 1040 1134 ok (non-closed singly connected) front 23600 23976 ok (non-closed singly connected) back 23600 23976 ok (non-closed singly connected) bottom 3835 4144 ok (non-closed singly connected) atmosphere 3835 4144 ok (non-closed singly connected) Kanal 613296 613514 ok (closed singly connected) Checking geometry... Overall domain bounding box (-16 -0.5 -9.5) (43 2.2 6.5) Mesh (non-empty, non-wedge) directions (1 1 1) Mesh (non-empty) directions (1 1 1) Boundary openness (-1.16337e-19 -3.50034e-14 4.62428e-15) OK. Max cell openness = 5.91374e-16 OK. Max aspect ratio = 5.79441 OK. Minimum face area = 7.73338e-05. Maximum face area = 0.0435317. Face area magnitudes OK. Min volume = 3.26601e-05. Max volume = 0.00872124. Total volume = 2543.98. Cell volumes OK. Mesh non-orthogonality Max: 56.7907 average: 8.29633 Non-orthogonality check OK. Face pyramids OK. ***Max skewness = 7.71711, 16 highly skew faces detected which may impair the quality of the results <<Writing 16 skew faces to set skewFaces Coupled point location match (average 0) OK. Failed 1 mesh checks. End Do you have any idea what to do? I've tried foamToVTK to show me the problems in paraView, but it seems that my whole stl-Geometry is the problem... Thank you! |
I state I'm a beginner too, so I can't answer with a solution.
But because I want to learn, and maybe this will be useful to also who can help you too, I'd want to know how did you create the stl file, what are your snappyHexMeshDict and the blockMeshDict files. Thanks |
