May 6, 2017, 05:38 |
turbulent flow
mohsen
Hello friends. my project is about a heat exchanger that there is a turbulator in cold part.and cold water flow is really turbulent . because of use this turbulator geometry in cold part is complex. I don't know what is the best method for meshing this heat exchanger. and what do i do for inflation this heat exchanger.
May 24, 2017, 00:08 |
CFD Expert
sila
Rep Power: 12 |
I can help you. Can you share the images of your geometry.. Regards silambarasan |
Problem with divergence | TDK | FLUENT | 13 | December 14, 2018 06:00 |
Why can i use a laminar solver for a turbulent flow? [Heat transfer problem] | blackbow | CFX | 1 | November 22, 2016 04:42 |
Particle deposition on circular cylinder in turbulent flow | Julian K. | CFX | 1 | October 3, 2011 17:51 |
Difference between recirculation zone and turbulent flow region | ashtonJ | Main CFD Forum | 0 | September 16, 2011 03:46 |
Inviscid Drag at subsonic, subcritical Mach # | Axel Rohde | Main CFD Forum | 1 | November 19, 2001 12:19 |
