Hassan Al-Siraj
Rep Power: 7 ![]() |
Hi everyone:
I need to create a triangular mesh on a unit sphere surface with a prespecified number of mesh points (12), then, extract a two files, one for the XYZ values of grid points, and the second file is for these mesh points connectivity. Actually, I get confused with many software and library tools available. I tried to use the Ansys APDL, but it does not give a way to specify the grid points, nor to export the connectivity info. I also found the GTS-library which seems very useful, however, It is using c language and object-oriented-programming, in which I cannot follow as my background is Fortran. Anyone faced such problem or can give me advice/guidance about what is the simplest way to this task? Thanks a lot |
Vimalraj
Rep Power: 11 ![]() |
Hi Hassan,
If you are not particular about triangular mesh, you can check GridPro. It creates structured hex mesh. The output grid format would be the same as per your requirement, (1. xyz value in one file, 2. connectivity info of the same on 2nd file, 3. boundary condition info on the 3rd file). You can also control the no. of grid points/cells. http://www.gridpro.com/ https://www.youtube.com/channel/UC8H...5FsZhRcYrZ-6ew Regards, Vimal |
Hassan Al-Siraj
Hello Vimal
Thanks for your help. I am tring to install the software now, but the question is that can it generate triangular mesh? Thanks |
Vimalraj
It can only create hex mesh.
Hassan Al-Siraj
Ok Vimal
Thanks for helping |
mesh generation problem |
Display Modes | |
Setting the height of the stream in the free channel | kevinmccartin | CFX | 12 | October 13, 2022 22:43 |
Meshing in StarCCM+: query regarding surface remesher and the "measure" tool | ns_chrys | STAR-CCM+ | 1 | June 2, 2014 06:06 |
CFX problem in ubuntu (linux) | Vigneshramaero | CFX | 0 | July 13, 2012 11:22 |
Errors running allwmake in OpenFOAM141dev with WM_COMPILE_OPTION%3ddebug | unoder | OpenFOAM Installation | 11 | January 30, 2008 21:30 |
Dominant Meshing Tool | Selina Tracy | Main CFD Forum | 6 | April 1, 2001 09:34 |
