Salome - Geometry
after installing Salome Salome-V8_4_0-univ_public on Ubuntu 18.04 I faced this problem where I cannot enter new entities like 2D /3D sketch The error message is:
GUI library corresponding to the users action can not be found or loaded. the terminal has the following message too. ************************************************** ************** Warning: module HEXABLOCKPLUGIN is improperly configured! Module HEXABLOCKPLUGIN will not be available in GUI mode! ************************************************** ************** ************************************************** ************** Warning: module HYBRIDPLUGIN is improperly configured! Module HYBRIDPLUGIN will not be available in GUI mode! ************************************************** ************** ************************************************** ************** Warning: module BLSURFPLUGIN is improperly configured! Module BLSURFPLUGIN will not be available in GUI mode! ************************************************** ************** ************************************************** ************** Warning: module HexoticPLUGIN is improperly configured! Module HexoticPLUGIN will not be available in GUI mode! ************************************************** ************** ************************************************** ************** Warning: module GMSHPLUGIN is improperly configured! Module GMSHPLUGIN will not be available in GUI mode! ************************************************** ************** ************************************************** ************** Warning: module NETGENPLUGIN is improperly configured! Module NETGENPLUGIN will not be available in GUI mode! ************************************************** ************** ************************************************** ************** Warning: module GHS3DPLUGIN is improperly configured! Module GHS3DPLUGIN will not be available in GUI mode! |
same problem here
I installed salome meca 2018 on a ubuntu 18.04 which was freshly installed.
I had to install python 2.7 and gcc and install libcanberra-gtk0 libcanberra-gtk-module finally net-tools. Also disable 3 faulty drivers at $HOME/salome_meca/V2018/prerequisites/debianForSalome/lib/libstdc++.* Now Salome Meca 2018 starts with the following warnings: stefan@ubuntu-engineering:~/salome_meca/appli_V2018$ ./salome runSalome running on ubuntu-engineering Searching for a free port for naming service: 2810 - OK Searching Naming Service + found in 0.1 seconds Searching /Kernel/Session in Naming Service +++++Warning: this type (SALOME_MED/MEDCouplingFieldDoubleCorbaInterface,objref) already exists, it will be ignored. found in 2.5 seconds Start SALOME, elapsed time : 2.7 seconds ************************************************** ************** Warning: module NETGENPLUGIN is improperly configured! Module NETGENPLUGIN will not be available in GUI mode! ************************************************** ************** ************************************************** ************** Warning: module GMSHPLUGIN is improperly configured! Module GMSHPLUGIN will not be available in GUI mode! ************************************************** ************** ************************************************** ************** Warning: module HYBRIDPLUGIN is improperly configured! Module HYBRIDPLUGIN will not be available in GUI mode! ************************************************** ************** Would be nice if someone had a suggestion on how to resolve these Warnings. |
