November 13, 2018, 03:22 |
Transform Mesh Problem in ICEM CFD
Vignesh Ravi
Rep Power: 7 |
Hi
I have a problem in ICEM CFD in copying the meshing repeatedly. The attached picture illustrates the problem clearly. I would like to copy the groove for 50 times for which I created a mesh transform copy with merge nodes option. But when I import in fluent I am getting a error of [Segmentation Violation]. I am pretty sure that the reason is due to the transform geometry because I exported once without this option and it worked fine. Kindly help me out. Thanks in advance |
How to create solid to fluid interface in Fluent using an ICEM CFD mesh. | ekraft | FLUENT | 1 | June 15, 2017 11:59 |
[snappyHexMesh] No layers in a small gap | bobburnquist | OpenFOAM Meshing & Mesh Conversion | 6 | August 26, 2015 09:38 |
[ICEM] Problem making structured mesh on a surface | froztbear | ANSYS Meshing & Geometry | 4 | November 10, 2011 08:52 |
ICEM CFD Prism Mesh Generation Problem with Ansys 12.0 & windows 7 OS | kh_thakor | ANSYS Meshing & Geometry | 1 | February 1, 2011 20:22 |
----------------2D mesh with ICEM CFD | Abir | FLUENT | 2 | September 12, 2008 23:55 |
