February 8, 2019, 08:27 |
Gmsh get all Surfaces of a Volume
Maximilian Köhler
Hey there,
I'm a new forum member and I would like to ask you, if you could help me out with the following problem: I have a bcc lattice domain for the stokes equation and I'm trying to set up the domain with gmsh. For all spherical cavitys of the bcc lattice I would like to assign a physical surface to it, such that the FE-solver can handle those surfaces as a noslip cond. Code:
// Gmsh project created on Thu Feb 7 09:15:11 2019 SetFactory("OpenCASCADE"); half_length = 0.5774; //+ Box(1) = {0, 0, 0, half_length, half_length, half_length}; //+ Sphere(2) = {half_length, half_length, half_length, 0.25, -Pi/2, Pi/2, 2*Pi}; //+ Sphere(3) = {half_length, half_length, 0, 0.25, -Pi/2, Pi/2, 2*Pi}; //+ Sphere(4) = {half_length, 0, 0, 0.25, -Pi/2, Pi/2, 2*Pi}; //+ Sphere(5) = {half_length, 0, half_length, 0.25, -Pi/2, Pi/2, 2*Pi}; //+ Sphere(6) = {0, 0, half_length, 0.25, -Pi/2, Pi/2, 2*Pi}; //+ Sphere(7) = {0, half_length, half_length, 0.25, -Pi/2, Pi/2, 2*Pi}; //+ Sphere(8) = {0, half_length, 0, 0.25, -Pi/2, Pi/2, 2*Pi}; //+ Sphere(9) = {0, 0, 0, 0.25, -Pi/2, Pi/2, 2*Pi}; //+ Sphere(10) = {half_length/2, half_length/2, half_length/2, 0.25, -Pi/2, Pi/2, 2*Pi}; //+ BooleanDifference{ Volume{1}; Delete; }{ Volume{10}; Volume{8}; Volume{9}; Volume{3}; Volume{4}; Volume{2}; Volume{5}; Volume{7}; Volume{6}; Delete; } //+ //+ Translate {0, 0, half_length} { Duplicata { Volume{1}; } } //+ Translate {half_length, 0, 0} { Duplicata { Volume{2}; Volume{1}; } } //+ Translate {0, half_length, 0} { Duplicata { Volume{4}; Volume{3}; Volume{2}; Volume{1}; } } Thanks in advance and kind regards |
February 8, 2019, 14:13 |
Solution with API
Maximilian Köhler
So, since I got frustrated with the Interface of Gmsh, I approached the API, which has a nice and clear documentation. My code to obtain everything marked and seperated.
Maybe it is useful for others Code:
import gmsh gmsh.initialize() gmsh.open("Mesh/symmetry_structure_gmsh.geo") gmsh.model.mesh.generate(3) gmsh.model.mesh.refine() gmsh.model.mesh.refine() gmsh.model.mesh.refine() entities = gmsh.model.getEntities() noslipboundary = [] boundary = [] dstuff = [] domain = [] points = [] for entity in entities: if gmsh.model.getType(entity[0],entity[1]) == 'Sphere' and entity[0] == 2: noslipboundary.append(entity[1]) elif gmsh.model.getType(entity[0],entity[1]) != 'Sphere' and entity[0] == 2: boundary.append(entity[1]) elif entity[0] == 3: domain.append(entity[1]) elif entity[0] == 1: dstuff.append(entity[1]) elif entity[0] == 0: points.append(entity[0]) gmsh.model.addPhysicalGroup(2,noslipboundary,3) gmsh.model.addPhysicalGroup(3,domain,2) gmsh.model.addPhysicalGroup(2,boundary,4) gmsh.model.addPhysicalGroup(1,dstuff,5) gmsh.model.addPhysicalGroup(0,dstuff,6) gmsh.model.setPhysicalName(3,1,"Domain") gmsh.model.setPhysicalName(2,2,"Boundary") gmsh.model.setPhysicalName(1,4,"1Dstuff") gmsh.model.setPhysicalName(2,3,"NoSlipBoundary") gmsh.model.setPhysicalName(0,5,"Points") gmsh.write("gmsh_api_symmetry_structure_gmsh.msh") gmsh.finalize() |
boundary, gmsh, mesh 3d, meshing, surface |
Display Modes | |
how to set periodic boundary conditions | Ganesh | FLUENT | 15 | November 18, 2020 07:09 |
alphaEqn.H in twoPhaseEulerFoam | cheng1988sjtu | OpenFOAM Bugs | 15 | May 1, 2016 17:12 |
[blockMesh] non-orthogonal faces and incorrect orientation? | nennbs | OpenFOAM Meshing & Mesh Conversion | 7 | April 17, 2013 06:42 |
[Gmsh] Import problem | ARC | OpenFOAM Meshing & Mesh Conversion | 0 | February 27, 2010 11:56 |
GMSH: Volume of two intersecting cubes | shangzung | Main CFD Forum | 1 | October 10, 2009 10:34 |
