gmsh spline delaunay 3D error message
3 Attachment(s)
I tried to make a 3D tee-pipe model with gmsh (2 intersecting cylinders, large and small).
I calculated the intersection curve points and made them spline sections. Next made a 1/8 section of the small pipe into transfinite lines, surfaces and volume. I was surprised to find out that gmsh can do the 2D-warped intersection surface. Next it nicely meshed every transfinite 2D-surface of this block. Finally it gives errors when I try 3D meshing: that Delauny system doesn't seem to accept the warped surface 1. Is this the end of a gmsh 3D-hex mesh trial or is there a solution to get this working ? I did try exactly the same volume in OpenFoam Blockmesh and it worked fine, but is more difficult to automate. Gmsh would be better, but apparently cannot handle this ? All suggestions welcome, Tom. |
