Home > Forums > Special Topics > Mesh Generation & Pre-Processing
making geometry in Salome so that meshing is optimal
Old   April 2, 2019, 08:29
Question making geometry in Salome so that meshing is optimal
Rene Hiemstra
Frisii is on a distinguished road
Hello all,
I'm new to geometry and mesh generation. I'm trying to make a simple tank with airflow into the tank on the bottom and outflow on the top. However because i'm trying to replicate a real object the outflow should consist of 4 separate pipes. How could I arrange the faces in Salome so that my mesh is of a good quality? Included is a picture of the top of the tank, with the location of the four exits on top. Is there a way create a good mesh with this kind of geometry? If this is not possible, or very hard. What would be a good substitution?
Previously I had one cylindrical face on top of a smooth cylinder, this however gave a very skewed mesh.
The plan is to run the simulation in openFoam eventually.
Frisii is offline   Reply With Quote
geometery, meshing 3d, openfoam, salome, salome meshing
python script to create geometry for salome, and then mesh 6863523 Mesh Generation & Pre-Processing 4 March 18, 2017 09:00
[Other] How to use finite area method in official OpenFOAM 2.2.0? Detian Liu OpenFOAM Meshing & Mesh Conversion 4 November 3, 2015 03:04
[foam-extend.org] problem when installing foam-extend-1.6 Thomas pan OpenFOAM Installation 7 September 9, 2015 21:53
Problem compiling a custom Lagrangian library brbbhatti OpenFOAM Programming & Development 2 July 7, 2014 11:32
Reg difficulties in meshing the geometry...Urgent arunraj ANSYS Meshing & Geometry 0 August 26, 2011 23:25
