Need for an expression in an edge Mesh generation |
September 9, 2019, 03:57 |
Mari vonkarman
Rep Power: 7 |
Hi all
I need to know the relation between the node location and the mesh index in a one-dimensional vertical edge. The edge is meshed by a successive ratios method as presented in the attached image in an old gambit version. The edge grids are generated by a double sided type. The edge length is 1 m and the edge has divided by 12 node. Above and below edge interval compression ratios are 1.3 and 1.4 relatively. Does anyone know which expression is suitable for the relation between Y and i (interval node index (i)) ? Y= f (I). What can f(i) be? Thanks a lot for any kind attention & idea. M.Vonkarman Last edited by Von_karman; September 9, 2019 at 10:41. |
[snappyHexMesh] SnappyHexMesh/splitMeshRegion : region1 in zone "-1" | GuiMagyar | OpenFOAM Meshing & Mesh Conversion | 3 | August 4, 2023 12:38 |
decomposePar problem: Cell 0contains face labels out of range | vaina74 | OpenFOAM Pre-Processing | 37 | July 20, 2020 05:38 |
[snappyHexMesh] No layers in a small gap | bobburnquist | OpenFOAM Meshing & Mesh Conversion | 6 | August 26, 2015 09:38 |
[ANSYS Meshing] Question about mesh generation learning | lnk | ANSYS Meshing & Geometry | 2 | July 7, 2012 06:45 |
Icemcfd 11: Loss of mesh from surface mesh option? | Joe | CFX | 2 | March 26, 2007 18:10 |
