Problelm Exporting Construct2D mesh to OpenFoam Please help |
October 5, 2019, 13:11 |
Os
Rep Power: 8 |
Hello ,
I am making a 2D airfoil simulation i ve found that Construct2D makes good mesh so i made 2D mesh with it but once i import it to OpenFoam and make a quality check I get Horrible quality mesh report Can you please help me identify the Problem here are the details : so i ve created a mesh O-grid mesh with elliptic topology (even though my TE is sharp i went for it because its what i am looking for ) so once i Copy the file to my openFoam case i use this command : Code:
plot3dToFoam naca.p3d -2D 1 -singleBlock -noBlank Code:
Reading 2D case by extruding points by 1 in z direction. Create time Reading 1 blocks block 0 nx:200 ny:100 nz:2 Reading block points block 0: Reading 20000 x coordinates... Reading 20000 y coordinates... Extruding 20000 points in z direction... Looking at cell 0 0 0 to determine orientation. Left-handed block. Merged points within 2.220446049e-16 distance. Merged from 40000 down to 39800 points. Creating cells Creating boundary patches --> FOAM Warning : From function Foam::polyMesh::polyMesh(const Foam::IOobject&, const Foam::Xfer<Foam::Field<Foam::Vector<double> > >&, const cellShapeList&, const faceListList&, const wordList&, const wordList&, const Foam::word&, const Foam::word&, const wordList&, bool) in file meshes/polyMesh/polyMeshFromShapeMesh.C at line 595 Found 39800 undefined faces in mesh; adding to default patch. Writing polyMesh End Code:
autoPatch 80 -overwrite Code:
Create time --> FOAM Warning : From function static Foam::instantList Foam::timeSelector::select0(Foam::Time&, const Foam::argList&) in file db/Time/timeSelector.C at line 274 No time specified or available, selecting 'constant' Create polyMesh for time = constant Time = constant Mesh stats points: 39800 internal points: 0 faces: 79003 internal faces: 39203 cells: 19701 faces per cell: 6 boundary patches: 5 point zones: 0 face zones: 0 cell zones: 0 Overall number of cells of each type: hexahedra: 19701 prisms: 0 wedges: 0 pyramids: 0 tet wedges: 0 tetrahedra: 0 polyhedra: 0 Checking topology... Boundary definition OK. Cell to face addressing OK. Point usage OK. Upper triangular ordering OK. Face vertices OK. Number of regions: 1 (OK). Checking patch topology for multiply connected surfaces... Patch Faces Points Surface topology defaultFaces 0 0 ok (empty) auto0 199 398 ok (non-closed singly connected) auto1 19701 19900 ok (non-closed singly connected) auto2 19701 19900 ok (non-closed singly connected) auto3 199 398 ok (non-closed singly connected) Checking geometry... Overall domain bounding box (-2.49962617 -2.99990654 0) (3.5 2.99990654 1) Mesh has 3 geometric (non-empty/wedge) directions (1 1 1) Mesh has 3 solution (non-empty) directions (1 1 1) Boundary openness (0 -1.43760457e-17 -1.03426383e-15) OK. ***High aspect ratio cells found, Max aspect ratio: 3.914098022e+101, number of cells 19701 <<Writing 19701 cells with high aspect ratio to set highAspectRatioCells Minimum face area = 7.004534805e-07. Maximum face area = 0.1461856339. Face area magnitudes OK. ***Zero or negative cell volume detected. Minimum negative volume: -0.01361617764, Number of negative volume cells: 19701 <<Writing 19701 zero volume cells to set zeroVolumeCells Mesh non-orthogonality Max: 180 average: 168.9684194 ***Number of non-orthogonality errors: 39203. <<Writing 39203 non-orthogonal faces to set nonOrthoFaces ***Error in face pyramids: 118206 faces are incorrectly oriented. <<Writing 79003 faces with incorrect orientation to set wrongOrientedFaces Max skewness = 1.450482967 OK. Coupled point location match (average 0) OK. Failed 4 mesh checks. End Do you have any idea about why i get such bad quality mesh and how can i fix That? any idea would Help Many Thanks |
Frequently Asked Questions about Installing OpenFOAM | wyldckat | OpenFOAM Installation | 3 | November 14, 2023 11:58 |
Moving mesh | Niklas Wikstrom (Wikstrom) | OpenFOAM Running, Solving & CFD | 122 | June 15, 2014 06:20 |
Inner geometry gets lost exporting mesh from ICEM CFD to CFX-Pre | powpow | CFX | 3 | December 20, 2012 09:14 |
salome, openfoam and moving mesh | prhlava | OpenFOAM Running, Solving & CFD | 8 | November 9, 2009 08:59 |
Convergence moving mesh | lr103476 | OpenFOAM Running, Solving & CFD | 30 | November 19, 2007 14:09 |
