October 17, 2019, 04:16 |
GMSH: defining an array to generate points
Hüseyin Can Önel
Rep Power: 7 |
Hello there,
In GMSH, I am able to create a series of points using For loop. I know that people are using external scripts (Matlab, Fortran etc.) to generate files in the Point(i)={x,y,z,c}; format from a data file (which is in x,y,z,c format). What I am trying to do is, use the data file directly in the .geo file without a format conversion. For that, I need to store the array in a variable in .geo file. Is there a way to do that? Thanks in advance, Hüseyin |
October 22, 2019, 12:09 |
Mikko
Rep Power: 12 |
Hi Hüseyin,
I don't know how if it's possible to store 2D arrays in GMSH .geo format but you can store 2 or 3 1D arrays. Here is an example of a script which contains NACA 0012 coordinates as arrays. It also contains a for loop which creates points from the arrays and a BSpline from the points. Obviously, this would be very straight-forward by using the Python interface of GMSH. Best, Mikko Code:
x = {1.0,0.991677,0.980364,0.9672594,0.9527094,0.9371906,0.9211098,0.9047307,0.888199,0.871589,0.8549374,0.838262,0.8215722,0.8048727,0.7881664,0.7714554,0.7547412,0.7380253,0.7213088,0.7045932,0.6878796,0.6711694,0.6544637,0.637764,0.6210716,0.6043879,0.5877143,0.5710523,0.5544034,0.5377692,0.5211515,0.504552,0.4879725,0.4714152,0.4548821,0.4383756,0.4218982,0.4054527,0.389042,0.3726696,0.3563391,0.3400549,0.3238215,0.3076446,0.2915302,0.2754859,0.2595202,0.2436435,0.2278683,0.2122105,0.1966898,0.181332,0.1661718,0.151256,0.1366496,0.1224422,0.1087546,0.09573936,0.08357044,0.07241381,0.06238752,0.05353091,0.04580157,0.03909828,0.03329271,0.02825461,0.02386618,0.02002762,0.01665766,0.01369187,0.01108041,0.008785821,0.006781149,0.005048426,0.003577154,0.002362688,0.001403607,0.0006990502,0.0002434807,2.600131e-05,2.600131e-05,0.0002434807,0.0006990502,0.001403607,0.002362688,0.003577154,0.005048426,0.006781149,0.008785821,0.01108041,0.01369187,0.01665766,0.02002762,0.02386618,0.02825461,0.03329271,0.03909828,0.04580157,0.05353091,0.06238752,0.07241381,0.08357044,0.09573936,0.1087546,0.1224422,0.1366496,0.151256,0.1661718,0.181332,0.1966898,0.2122105,0.2278683,0.2436435,0.2595202,0.2754859,0.2915302,0.3076446,0.3238215,0.3400549,0.3563391,0.3726696,0.389042,0.4054527,0.4218982,0.4383756,0.4548821,0.4714152,0.4879725,0.504552,0.5211515,0.5377692,0.5544034,0.5710523,0.5877143,0.6043879,0.6210716,0.637764,0.6544637,0.6711694,0.6878796,0.7045932,0.7213088,0.7380253,0.7547412,0.7714554,0.7881664,0.8048727,0.8215722,0.838262,0.8549374,0.871589,0.888199,0.9047307,0.9211098,0.9371906,0.9527094,0.9672594,0.980364,0.991677,1.0}; y = {0.00126,0.002421811,0.003982079,0.005762782,0.00770723,0.009744292,0.01181606,0.0138865,0.01593654,0.01795702,0.01994386,0.02189533,0.02381076,0.02568989,0.02753259,0.02933869,0.03110797,0.03284008,0.03453454,0.03619074,0.03780792,0.03938518,0.04092147,0.04241557,0.04386613,0.04527161,0.04663031,0.04794038,0.04919976,0.05040625,0.05155744,0.05265072,0.05368329,0.05465216,0.05555408,0.05638562,0.05714307,0.0578225,0.05841969,0.05893014,0.05934906,0.05967133,0.05989147,0.06000362,0.06000152,0.05987849,0.05962734,0.0592404,0.05870947,0.05802584,0.05718031,0.05616342,0.05496573,0.05357861,0.05199553,0.05021437,0.04824084,0.0460927,0.04380301,0.04141953,0.03899781,0.03659002,0.03423525,0.03195587,0.02975941,0.02764309,0.02559815,0.02361286,0.0216745,0.01977036,0.01788831,0.01601718,0.01414714,0.01227025,0.01038132,0.008479151,0.006567428,0.004656927,0.002761035,0.0009055955,-0.0009055955,-0.002761035,-0.004656927,-0.006567428,-0.008479151,-0.01038132,-0.01227025,-0.01414714,-0.01601718,-0.01788831,-0.01977036,-0.0216745,-0.02361286,-0.02559815,-0.02764309,-0.02975941,-0.03195587,-0.03423525,-0.03659002,-0.03899781,-0.04141953,-0.04380301,-0.0460927,-0.04824084,-0.05021437,-0.05199553,-0.05357861,-0.05496573,-0.05616342,-0.05718031,-0.05802584,-0.05870947,-0.0592404,-0.05962734,-0.05987849,-0.06000152,-0.06000362,-0.05989147,-0.05967133,-0.05934906,-0.05893014,-0.05841969,-0.0578225,-0.05714307,-0.05638562,-0.05555408,-0.05465216,-0.05368329,-0.05265072,-0.05155744,-0.05040625,-0.04919976,-0.04794038,-0.04663031,-0.04527161,-0.04386613,-0.04241557,-0.04092147,-0.03938518,-0.03780792,-0.03619074,-0.03453454,-0.03284008,-0.03110797,-0.02933869,-0.02753259,-0.02568989,-0.02381076,-0.02189533,-0.01994386,-0.01795702,-0.01593654,-0.0138865,-0.01181606,-0.009744292,-0.00770723,-0.005762782,-0.003982079,-0.002421811,-0.00126}; p = newp; For i In {0: #x[]-1} Point(p + i) = {x[i], y[i], 0, 0.1}; EndFor BSpline(1) = {1:#x[],1}; |
October 22, 2019, 12:56 |
#3 | |
Hüseyin Can Önel
Rep Power: 7 |
The thing is, I am trying to read the x-y data from a file, which is usually in column format, such as x_column, y_column. In your case, I guess my only option is to provide x and y data externally in separate files (one for x and one for y) in row format and then include them in the .geo file. Example: contents of x_coords.dat file: Code:
1.0,0.991677,0.980364,0.9672594,0.9527094,0.9371906,................ Code:
x={Include "x_coords.dat"}; |
October 23, 2019, 04:29 |
Mikko
Rep Power: 12 |
I would suggest using the API. Here is an example code in Python how to open a .dat file and create similar BSpline with it.
import gmsh datFile = 'naca0012.dat' gmsh.initialize() model = gmsh.model factory = model.geo with open(datFile) as fin: for line in fin: try: x, y = map(float,line.split()) factory.addPoint(x, y, 0) except ValueError: print("Skipped line: ", line) factory.synchronize() ids = list(range(1, len(model.getEntities())+1)) ids.append(1) # [1,2,3,...,N,1] spline = factory.addBSpline(ids) factory.synchronize() gmsh.fltk.run() gmsh.finalize() |
[snappyHexMesh] SHM Layer Addition Phase | dickcruz | OpenFOAM Meshing & Mesh Conversion | 4 | November 1, 2018 07:05 |
[blockMesh] BlockMeshmergePatchPairs | hjasak | OpenFOAM Meshing & Mesh Conversion | 11 | August 15, 2008 07:36 |
Defining a surface from points or edges in CFXpost | Gui | CFX | 9 | July 26, 2007 15:12 |
Defining a surface from edges or points in CFXpost | Gui | CFX | 0 | July 25, 2007 16:03 |
Defining points at real dimensions | John | CFX | 0 | February 21, 2002 05:21 |
