How to calculate the mesh once I have the thickness BL |
November 21, 2019, 14:05 |
Rep Power: 7 |
Hello everyone
I'm studying boundary layer. When I do an analysis in order of magnitude I get the classic dependence of a thin plate as inverse of the square root of the Reynolds number, so I know the thickness. So how many cells do I need to model the boundary layer with this thickness? For example, if I calculate meters, how many cells should I have between surface and , three, four? The problem is stationary and incomprehensible, but viscosity is relevant with the contour condition as null velocity on surface. My main question is how should I proceed once I know the order of magnitude of the boundary layer Thanks for everything. Last edited by jmenendez; November 21, 2019 at 20:18. |
bounday layer, mesh bounday layer |
[snappyHexMesh] Creating very fine, high accuracy mesh with snappyHexMesh | JD_Welch | OpenFOAM Meshing & Mesh Conversion | 10 | July 5, 2023 11:50 |
[snappyHexMesh] Strange colors on the mesh | LeoCal | OpenFOAM Meshing & Mesh Conversion | 2 | July 5, 2018 05:35 |
[Gmsh] 2D Mesh Generation Tutorial for GMSH | aeroslacker | OpenFOAM Meshing & Mesh Conversion | 12 | January 19, 2012 03:52 |
fluent add additional zones for the mesh file | SSL | FLUENT | 2 | January 26, 2008 11:55 |
Icemcfd 11: Loss of mesh from surface mesh option? | Joe | CFX | 2 | March 26, 2007 18:10 |
