Is there any reference explaining mesh strategy based on non-dimensional numbers? |
April 19, 2020, 05:11 |
Hector Redal
Rep Power: 16 |
I am interested in knowing if there is any reference / article, that explains how to mesh or how to define the mesh density of a mesh based on non-dimensional numbers (i.e., Reynolds number). I usually do a convergence analysis, but maybe this convergence analysis is not enough for capturing all the physical processes that can occur in the domain. So, I am wondering if there is a recommendation to follow / use when meshing. For example, at high reynolds numbers, the boundary layer is tiny, but the mesh density in that boundary layer should be high enough for capturing the physical process. Thanks for your kind support. Best regards, Hector. |
Second Derivative Zero - Boundary Condition | fu-ki-pa | OpenFOAM | 11 | March 27, 2021 04:28 |
mass flow in is not equal to mass flow out | saii | CFX | 12 | March 19, 2018 05:21 |
problem with turbulence models after compilation? | lfgmarc | OpenFOAM Programming & Development | 19 | November 20, 2013 00:50 |
Installing OpenFOAM-1.5-dev on a cluster | ZKM | OpenFOAM Installation | 4 | December 25, 2010 15:59 |
G95 + CGNS | Bruno | Main CFD Forum | 1 | January 30, 2007 00:34 |
