Home > Forums > Special Topics > Mesh Generation & Pre-Processing
gmsh crashing during BooleanDifference with many volumes
Old   May 12, 2020, 05:14
Default gmsh crashing during BooleanDifference with many volumes
Adam
Adam_K is on a distinguished road
I am having an issue with gmsh crashing when I try to do many boolean operations. I want to generate a porous volume, where the medium is the empty space around overlapping spheres. My code, below, is meant to subtract the spheres from the starting box. It works fine for N up to 385, but if I used N = 386 or greater, gmsh crashes (on both of my computers).
Did I do something wrong? Or is this a limitation with gmsh/OpenCASCADE? At this point, I'm not even meshing, just defining the surfaces so I don't think it's a memory issue.
SetFactory("OpenCASCADE");
// x,y,z positions for the spheres (not shown for brevity)
N = 500;        // number of spheres
R = 0.1;      // cylinder radius
X = 1;        // size of domain in x-direction
Y = 1;        // size of domain in y-direction
Z = 10;        // size of domain in z-direction
LC = R;    // mesh critical length
// define entire domain
Box(1) = {0,0,0,X,Y,Z};
// define empty list for volume index numbers
VolIndex[] = {};
// for loop that places N spheres
For t In {1:N}
  NV = newv;    //new volume index
  Sphere(NV) = {x[t-1], y[t-1], z[t-1], R}; // Defines the Sphere
  VolIndex[] += NV; //adds this volume index to the list
EndFor
// Boolean subtraction of the total domain, minus the spheres
// both the original domain, and the original spheres are deleted
BooleanDifference{ Volume{1}; Delete; }{ Volume{VolIndex[]}; Delete; }
Adam_K is offline   Reply With Quote
[Gmsh] 3D Hex Mesh after BooleanDifference in Gmsh bhargav1195 OpenFOAM Meshing & Mesh Conversion 0 June 28, 2018 09:39
[Gmsh] Converting gmsh to OpenFoam Friendly OpenFOAM Meshing & Mesh Conversion 3 June 26, 2018 06:46
[Gmsh] 2D Mesh Generation Tutorial for GMSH aeroslacker OpenFOAM Meshing & Mesh Conversion 12 January 19, 2012 04:52
[Gmsh] Import problem ARC OpenFOAM Meshing & Mesh Conversion 0 February 27, 2010 11:56
Copying tranfsinite volumes in gmsh shangzung Main CFD Forum 0 December 10, 2009 04:04
