Home > Forums > Special Topics > Mesh Generation & Pre-Processing
SnappyHexMesh questions
Old   June 14, 2020, 15:10
Question SnappyHexMesh questions
M.Lewis
Ryoko is on a distinguished road
I'm having a couple of issues with Snappy. The first is I'm getting blisters on my model's surface as seen in the first picture. The second issue is a strange quilting pattern in the refined mesh instead of a smoothly increasing grid distribution towards the model surface. I imagine these are just issues that need tweaking in the dictionary. But I don't know where to look. I'm using the dictionary from the DCTHull tutorial.
Ryoko is offline   Reply With Quote
Old   June 20, 2020, 23:40
Rango is on a distinguished road
Have you checked the quality of your stl file(s)? Try to increase "tolerance" in "snapControls" part to see if you can get a smoother surface. If it is possible, please share your test case or a simpler version of it in order to get some more detailed and customized help on your specific problems.
Cheers
Rango is offline   Reply With Quote
Old   June 21, 2020, 11:52
M.Lewis
I fiddled with the some of the settings in the SHM dictionary and the problem seems to have gone away. I'm not sure which one did the trick. I think it was the number of iterations.
[snappyHexMesh] OFW10 snappyHexMesh Training Session Questions (follow up) chegdan OpenFOAM Meshing & Mesh Conversion 3 July 20, 2015 12:10
[snappyHexMesh] snappyHexMesh questions??? liu-t11 OpenFOAM Meshing & Mesh Conversion 3 March 3, 2015 17:57
[snappyHexMesh] questions about snappyHexMesh xurenyi OpenFOAM Meshing & Mesh Conversion 0 June 11, 2014 03:53
[snappyHexMesh] some questions in SnappyHexMesh Cloudy1988 OpenFOAM Meshing & Mesh Conversion 1 August 23, 2012 14:56
[snappyHexMesh] A few simple questions about SnappyHexMesh. suitup OpenFOAM Meshing & Mesh Conversion 1 December 19, 2009 15:30
