Locally refining mesh over cylinder in Gmsh
I want to mesh a cylinder in Gmsh with a finer mesh at a particular circular location along its height. I have succeeded partially with the code below:
-------------------------------------------------------------------------------- SetFactory("OpenCASCADE"); //Create a circle Circle(1) = {0, 0, 6, 1, 0, 2*Pi}; Curve Loop(1) = {1}; Plane Surface(1) = {1}; //Extrude into a cylinder 4 units along Z-direction and 6 units along -Z direction Extrude {0, 0, 4} { Surface{1}; } Extrude {0, 0, -6} { Surface{1}; } //Convert Circle 1 into transfinite line so that a fine mesh can be obtained in its vicinity Transfinite Line{1}=100; -------------------------------------------------------------------------------------- The mesh is coming out fine (when I do a 2D or 3D mesh) except at the location where the generator of the extruded cylinder intersects the circle (here the mesh is coarse). Any ideas on how to overcome the problem and obtain a uniformly fine mesh at Circle(1)? |
At the moment, you are only defining the cell size along the line. You should also define the cell size elsewhere. For instance, define the cell sizes at the points:
Characteristic Length {1} = 0.1; Characteristic Length {2, 3} = 1; |
Your solution worked :) Thanks a lot.
But what do points 1,2,3 correspond to? Are they the three points at which cylinder's generator-line intersects the three circles? |
You are welcome. If you visually look at the geometry, it contains only 3 points. The points are the start/end points of each circle.
