Cyclic boundary distance of the transformed centre is greater and failed. |
February 25, 2021, 15:42 |
#1 | |
Yovanny Morales Hernández
Rep Power: 7 |
Hello everyone,
I'm trying to configure a geometry to give some rotational capabilities without using MRF(Multiple reference frame) that gives virtual rotational capabilities, instead I want to use real rotational capabilities. To start exploring those capabilities I have selected the type boundary conditions cyclic and cyclycAMI, by far I have successfully created one pair of patches with these characteristics, however when I tried to create a new pair in exactly the same way I failed to configure it, I am absolutely sure that the two new new neighboring patches are in the exact same coordinates. Bellow I write the log of the fatal error. I have found a thread related to the topic but unfortunately it has no answers so far I post the link to that thread here CyclicAMI boundaries Issues. I have kept looking for an answer on the net and I found something related to it, unfortunately I am just a beginner and this information is out of my league, I post the link here https://bugs.openfoam.org/view.php?id=3447. According to this last post there is a bug problem in openfoam causing malfunctions in certain situations but I am lacking in the knowledge to find the relation of this information to my problem. Bellow I post the blockMeshDict so you can verify that the new pair of surfaces (ArribaCyclicRotor and ArribaCyclicStator) are neighbors with the same coordinates, you can also verify the old pair of surfaces (AbajoCyclicStator and AbajoCyclicRotor) that were successfully created. Thanks in advance for your help! The fatal error gives this log: Quote:
/*--------------------------------*- C++ -*----------------------------------*\ ========= | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox \\ / O peration | Website: https://openfoam.org \\ / A nd | Version: dev \\/ M anipulation | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class dictionary; object blockMeshDict; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // convertToMeters 1; vertices ( (0 0 0) //0 (0.47 0.47 0) //1 (1.53 0.47 0) //2 (1.998 0 0) //3 (0 0 0.05) //4 (0.47 0.47 0.05) //5 (1.53 0.47 0.05) //6 (1.998 0 0.05) //7 (0 0 0.25) //8 (0.47 0.47 0.25) //9 (1.53 0.47 0.25) //10 (1.998 0 0.25) //11 (0 0 1.2) //12 (0.47 0.47 1.2) //13 (1.53 0.47 1.2) //14 (1.998 0 1.2) //15 (0.95 0.95 0) //16 (1.05 0.95 0) //17 (0.95 0.95 0.05) //18 (1.05 0.95 0.05) //19 (0.95 0.95 0.05) //20 (1.05 0.95 0.05) //21 (0.47 0.47 0.05) //22 (1.53 0.47 0.05) //23 (0.95 0.95 0.25) //24 (1.05 0.95 0.25) //25 (0.47 0.47 0.25) //26 (1.53 0.47 0.25) //27 (0.47 0.47 0.25) //28 (1.53 0.47 0.25) //29 (0.95 0.95 0.25) //30 (1.05 0.95 0.25) //31 (0.95 0.95 1.2) //32 (1.05 0.95 1.2) //33 ); xcells 20; ycells 20; zcells 5; zcells1 20; zcells2 125; blocks ( //bloque 0 hex (0 3 2 1 4 7 6 5) ($xcells $ycells $zcells) simplegrading (1 1 1) //bloque 1 hex (4 7 6 5 8 11 10 9) ($xcells $ycells $zcells1) simplegrading (1 1 1) //bloque 2 hex (8 11 10 9 12 15 14 13) ($xcells $ycells $zcells2) simplegrading (1 1 1) //bloque 3 hex (1 2 17 16 5 6 19 18) ($xcells $ycells $zcells) simplegrading (1 1 1) //bloque 4 hex (22 23 21 20 26 27 25 24) RotatingZone ($xcells $ycells $zcells1) simplegrading (1 1 1) //bloque 5 hex (28 29 31 30 13 14 33 32) ($xcells $ycells $zcells2) simplegrading (1 1 1) ); edges ( arc 1 2 (1 0.25 0) arc 5 6 (1 0.25 0.05) arc 22 23 (1 0.25 0.05) arc 9 10 (1 0.25 0.25) arc 26 27 (1 0.25 0.25) ); boundary ( Fondo { type wall; faces ( (0 3 2 1) (1 2 17 16) ); } AbajoCyclicStator { type cyclic; neighbourPatch AbajoCyclicRotor; faces ( (5 6 19 18) ); } AbajoCyclicRotor { type cyclic; neighbourPatch AbajoCyclicStator; faces ( (22 23 21 20) ); } ArribaCyclicRotor { type cyclic; neighbourPatch ArribaCyclicStator; faces ( (26 27 25 24) ); } ArribaCyclicStator { type cyclic; neighbourPatch ArribaCyclicRotor; faces ( (28 29 31 30) ); } ); mergePatchPairs ( ); // ************************************************************************* // Last edited by yMorH; February 28, 2021 at 11:12. Reason: Adding some content and quoting errors and coding files |
February 26, 2021, 18:17 |
Found an unexplainable solution
#2 | |
Rep Power: 7 |
Well reading some threads related to rotational cyclic conditions I found this thread suggesting changing boundary conditions from cyclic to cyclicGGI to solve the problem, I changed it and I successfully build the mesh with no furder changes. However in the openfoam-dev documentation, the version I am running there is no information related to this type of boundary condition.
I keep reading about this boundary condition and I found that it requires a foam version called foam-extent 4.0 to run a case, I don't have this version installed in my machine so I decided to use a different version that I have installed of openfoam, v2012 of OpenFOAM® and I change the boundary condition to cyclic and the error change to: Quote:
Anyone has an explanation of these behaviors in the openfoam-dev and v2012? |
August 11, 2023, 13:23 |
So, I had a similar problem. I fixed the issue by reversing the direction of arc or spline.
Instead of: Code:
arc 1 2 (1 0.25 0) arc 5 6 (1 0.25 0.05) Code:
arc 1 2 (1 0.25 0) arc 6 5 (1 0.25 0.05) |
