Setting physical entities with Gmsh using an STL object |
March 8, 2021, 07:51 |
Prapanch Name
Supppose I have an STL file for a 3d part and I want to apply a boundary condition to a face of it. Note that the STL comes as a single part. Is there a way I can set the physical entities (ID) for a group of nodes that belong to the patch within Gmsh?
For example, I have an part for which I need to to modal analysis with calculix. Can I pick a patch, and assign the nodes of the patch a fixed boundary condition and then use calculix to solve the modes? If yes, what is the procedure in Gmsh. If you have a video tutorial that you found somewhere, please share that as well. Thanks and Regards, PN. |
April 8, 2021, 07:45 |
France
Hi
I have the same problem. Have you found any solution for that?. In my case I have to import into the openfoam. Thanks and Regards, Pavithra |
boundary condition, gmsh, stl |
How to select physical volume in Gmsh | Pranto | OpenFOAM Pre-Processing | 1 | August 12, 2023 17:12 |
GMSH: Access extruded physical geometry | BEM | Mesh Generation & Pre-Processing | 0 | November 9, 2020 10:55 |
Compilation error OF1.5-dev on Suse10.3 | darenyang | OpenFOAM Installation | 0 | April 29, 2009 04:55 |
[blockMesh] BlockMeshmergePatchPairs | hjasak | OpenFOAM Meshing & Mesh Conversion | 11 | August 15, 2008 07:36 |
