Home > Forums > Special Topics > Mesh Generation & Pre-Processing
Generating mesh for gyroid/minimal surface geometry
Old   May 27, 2021, 06:00
Default Generating mesh for gyroid/minimal surface geometry
biltu M
biltu is on a distinguished road
Dear CFDians,
Greetings!
I have a gyroid geometry designed in nTopology. I want to simulate fluid flow through the gyroid in CFX. I imported the *.stl file in geometry modeller and can see the geometry.
However, I am not able to generate mesh for the model. The mesh generation crashes after generating surface mesh. So, I want to ask how can I generate mesh for gyroid like model in ANSYS.
Thanking you for your help.
System configuration: 2.20 GHz, 128 GB RAM
PS: Gyroid is a minimal surface geometry with more than 10K faces. Google for details.
With best regards,
Biltu
biltu is offline   Reply With Quote
[snappyHexMesh] Holes in internal mesh when adding boundary layer snappyHex otaolafr OpenFOAM Meshing & Mesh Conversion 4 April 8, 2025 15:01
[snappyHexMesh] snappyHexMesh does not create any mesh except one for the reference cell Arman_N OpenFOAM Meshing & Mesh Conversion 1 May 20, 2019 17:16
[snappyHexMesh] Creating multiple multiple cell zones with snappyHexMesh - a newbie in deep water! divergence OpenFOAM Meshing & Mesh Conversion 0 January 23, 2019 04:17
[snappyHexMesh] snappyHexMesh - geometry does not appear in Mesh czhongrong OpenFOAM Meshing & Mesh Conversion 1 January 20, 2016 05:26
Cluster ID's not contiguous in compute-nodes domain. ??? Shogan FLUENT 1 May 28, 2014 15:03
