Home > Forums > Special Topics > Mesh Generation & Pre-Processing
Inflation layers over inlets/outlets
Old   June 29, 2021, 07:56
Default Inflation layers over inlets/outlets
ergk-10
ergk-10 is on a distinguished road
I am setting up a transient simulation with an inlet and outlet that will only be activated after a certain amount of time, until which they will be modelled as walls. As walls it is of course prudent to have an inflation layer at these surfaces to capture the large velocity gradient, however to keep the mesh simple I am considering leaving the mesh unchanged once the inlet/outlet BCs are activated.
I am now wondering if there is a downside to having an inflation layer over an inlet/outlet surface beyond maybe having more elements than are really necessary?
In general, what are the implications of using an inflation layer at an inlet/outlet? Are there accuracy/stability reasons to avoid this? Or is it simply overkill in most situations?
Thanks for any thoughts!
ergk-10 is offline   Reply With Quote
Old   July 22, 2021, 03:24
Colinda
colinda1 is on a distinguished road
On a converged simulation it should not have an adverse impact I believe. There may be even a (small) positive impact because of the lower numerical dissipation in case of streamwise flow field gradients in the inlet region.
The convergence may be slower and this not only because of the higher cell count but especially because of the local time stepping. The local time step is linked directly to the local cell size through the CFL number. So you would have a very low time step and it may take time to really converge. Because of the very small time step it may even look like your simulation is converged as residuals and quantities of interest vary so little that they look constant.
colinda1 is offline   Reply With Quote
inflation, inlet, layer, mesh, outlet
ANSYS Fluent Meshing: Incomplete Inflation Layers sbro FLUENT 1 October 26, 2020 15:04
[ANSYS Meshing] Inflation layers element quality frossi ANSYS Meshing & Geometry 0 July 2, 2016 20:19
[ANSYS Meshing] Guidelines for inflation layers Euan001 ANSYS Meshing & Geometry 2 May 27, 2016 07:49
[ANSYS Meshing] Inflation Layers disappearing - airfoil krekel13 ANSYS Meshing & Geometry 0 January 24, 2015 13:55
Fluent diverges when using inflation layers ziggo FLUENT 4 August 9, 2013 12:11
