Home > Forums > Special Topics > Mesh Generation & Pre-Processing
How to extrude unstructured mesh from a surface with more than 5 points
Old   July 21, 2021, 15:33
Default How to extrude unstructured mesh from a surface with more than 5 points
Icaro Amorim de Carvalho
PenPencil is on a distinguished road
Hello everyone,
I am trying to simply extrude an unstructured 2D mesh for some length. My 2D mesh is fine, but when I extrude, it seems that Gmsh does not extrude the elements as well, so what I am left with is a mesh without interior elements.
Please check the first image to see the geometry and the 2D unstructured mesh. The second image shows the net result after extrusion. Is there any workaround that I am missing out here?
Thanks.
Below you find my code:
lc=1.0;
Point(1) = {0, 5, 0, lc};
Point(2) = {0, 0, 0, lc};
Point(3) = {5, 5, 0, lc};
Point(4) = {5, 0, 0, lc};
Point(5) = {2.5, -2.5, 0, lc};
Line(1) = {2, 1};
Line(2) = {4, 3};
Line(3) = {5, 4};
Line(4) = {5, 2};
Line(5) = {1, 3};
Curve Loop(1) = {1, 5, -2, -3, 4};
Plane Surface(1) = {1};
Transfinite Surface {1,2,3,4,5};
//Extrude {0, 0, 50} {
//  Point{1}; Point{2}; Point{5}; Point{3}; Point{4}; Curve{1}; Curve{4}; Curve{5}; Curve{2}; Curve{3}; Surface{1};
//  Layers {5};
Correction: the title of this thread should refer to surface with more than 4 points, not 5.
PenPencil is offline   Reply With Quote
Old   July 21, 2021, 17:07
I have figured out the problem. For future reference for anyone, here is the corrected code:
lc=1.0;
Line(1) = {2, 1};
Line(2) = {4, 3};
Line(3) = {5, 4};
Line(4) = {5, 2};
Line(5) = {1, 3};
//Transfinite Surface {1,2,3,4,5};
Layers {5};
[snappyHexMesh] non uniform mesh near the stl object vava10 OpenFOAM Meshing & Mesh Conversion 0 January 31, 2021 14:41
SU2-7.0.1 on ubuntu 18.04 hyunko SU2 Installation 7 March 16, 2020 04:37
[snappyHexMesh] Creating multiple multiple cell zones with snappyHexMesh - a newbie in deep water! divergence OpenFOAM Meshing & Mesh Conversion 0 January 23, 2019 04:17
[Gmsh] 3D mesh using transfinite surface + extrude with layer? CFD-Lover OpenFOAM Meshing & Mesh Conversion 0 July 5, 2016 02:26
[mesh manipulation] Importing Multiple Meshes thomasnwalshiii OpenFOAM Meshing & Mesh Conversion 18 December 19, 2015 18:57
