How can I Compile OpenCASCADE to GMSH?
Hello everybody,
I am trying to import a .step file into gmsh, that I created using SolidWorks. Every time I try I get this error: "Error : Gmsh requires OpenCASCADE to import shape" I couldn't find a way to install or compile OpenCascade to gmsh. Is there anyone who can help with that? Thank you. |
Solution
Hello again everybody,
After following the steps in the Cascade's website for dependencies : https://dev.opencascade.org/doc/occt...rty_linux.html , I followed the GMSH's website for compilation with Cascade. I only used it for Cascade because I run into some errors while building gmsh from the source. https://gitlab.onelab.info/gmsh/gmsh...sh-compilation After completing the Cascade compilation, I downloaded GMSH from the website instead of building it from the source. It works for now. |
