Home > Forums > Software User Forums > Fidelity CFD
Autoblade - Adjust Aspect Ratio
Old   April 5, 2017, 04:49
Default Autoblade - Adjust Aspect Ratio
Michael Hopfinger
karwendel is on a distinguished road
I wondering how can I adjust the aspect ratio of my blade? In particular, how can I alter the chord lenght of the chord? My blade is defined via 20 sections. It should no be a big deal, but somehow I don't know how to do it. Also, the two tutorials provided and the user guide couldn't help me out here.
To change the hight of the blade, I suppose I need to change the hub respectively the shroud geometry and adjust the stream surfaces?!
Thanks a lot!
p.s.: I've asked the same question at the NUMECA autoblade forum. When I get an answer there, I will post it
karwendel is offline   Reply With Quote
Old   April 5, 2017, 05:08
Michael Hopfinger
I found it.
You need to toggle Model Editor/Construction Plane/Reference Length/True chord based. Then you can change the chord length.
Old   April 10, 2017, 00:05
Hamid Zoka
Hamidzoka is on a distinguished road
Hi;
In Autoblade there are two methods to define the arifoil: "meridional chord based" and "true chord based" which can be found on left side of the autoblade screen under the "main blade" icon colored in green.
Once "meridional chord based" strategy is selected you can change axial chord as an independent parameter but there is no direct control on chord value.
Instead, when "true chord based" method is selected true chord as an independet parameter is added to parameters of each section. So that you can easily change the true chords at each section and change the aspect ratio.
On the other hand by changing the hub and tip radii on"stream surface" parameter length of the blade can also be changed which provides more flexibility to change the aspect ratio.
regards
Hamidzoka is offline   Reply With Quote
Problem with divergence TDK FLUENT 13 December 14, 2018 06:00
[Other] Aspect Ratio CFX Solver tomson199 ANSYS Meshing & Geometry 4 August 27, 2015 10:12
Grid Aspect Ratio harishameed33 Main CFD Forum 1 August 11, 2012 22:35
pressure eq. "converges" after few time steps maddalena OpenFOAM Running, Solving & CFD 69 July 21, 2011 07:42
High Aspect Ratio elements Flavio CFX 2 November 24, 2006 12:01
