November 16, 2018, 11:42 |
Unsteady - Modal Coupling
Ko Shine
Rep Power: 7 |
I’ve been trying to run the FSI unsteady simulation using modal coupling method in FINE/Turbo (version 12.1). I used fct(time) to impose the generalized displacement for the mode shape. However, I got this message when I started the solver: “! Error in the number of points for displacement profile, nData = 0” What does this message exactly mean? I’ve given enough points for the displacement though. I did run the same model using NLH method. There wasn’t any problem with that. The idea is to compare the two runs (unsteady and NLH). On a separate question, I’m also wondering if it is possible to change IBPA in unsteady mode in a same way as Harmonic mode. Thank you. Last edited by Ko_Shine; November 17, 2018 at 06:51. |
March 15, 2020, 20:32 |
Andrija Grbavac
Rep Power: 6 |
Hey Ko_Shine,
did you solve the problem? I have the same problem and couldn't figure out how to fix it. Best regards, AndrijaG |
March 16, 2020, 06:27 |
Ko Shine
Rep Power: 7 |
Yeah I solved that problem more than one year ago. In my case, there were two groups of patches that were coupled sharing the same mode shape file. I needed to group them together as a single patch. I hope it helps! |
March 16, 2020, 20:42 |
Andrija Grbavac
Rep Power: 6 |
Hey Ko_Shine,
thanks for your fast response. I'll try to fix it with that hint. Thank you! |
FSI problem with system coupling: Fail to couple FLUENT | sophieUNSW | FLUENT | 16 | October 1, 2020 06:20 |
Difference between stagger/coupling iteration and coupling step | Jiricbeng | CFX | 1 | September 13, 2016 03:37 |
Coupling time duration, Coupling time steps | Jiricbeng | CFX | 0 | April 29, 2015 09:37 |
Star ccm 9.02 - unsteady flux dissipation correction | fivos | STAR-CCM+ | 4 | April 28, 2014 10:37 |
Unsteady flow- pressure velocity coupling | Hooman | Main CFD Forum | 0 | June 7, 2010 11:31 |
