October 11, 2007, 08:57 |
Help HIGH RESIDUALS
Hi
Hope any mathematician can help me. I am not using a cfd code but using a propriety code (not much inofrmation is avaiable about it) based on two fluid model with staggered mesh scheme. I have used steady state flowrates values as input BC with outlet BC constant at atmospheric pressure, I got results that were far from experimental values. next I tired putting experimental values (flow rates) as input BC keeping outletBC constant at atmpospheric pr. I also tried the reverse keeping experimental measured time series at outlet and keeping inlet BC (steady state values) at inlet BC. what I want to know is that in both cases there are few scattered high residual peaks in initial simulation till 400s and then the residuals drops down to 10-8 and below. I was wondering whether the trends (of varaibles like P, V etc) obtained in first 500s are the artfacts of these initail high residuals peaks or physics behind the phenomena? looking forward to hear any suggestion. |
High residuals | ecram | Siemens | 4 | April 20, 2020 11:14 |
Residuals converged but high | Gilles | CFX | 2 | September 30, 2008 19:05 |
help high initial residuals | Aly | FLUENT | 0 | October 11, 2007 09:04 |
residuals | Karl | CFX | 2 | June 24, 2003 23:13 |
residuals | andrea | Siemens | 0 | March 6, 2002 09:41 |
