Home > Forums > Software User Forums > OpenFOAM > OpenFOAM Bugs
OF 1.6-ext interDyMFoam damBreakWithObstacle tutorial crashes
Old   May 20, 2011, 05:08
Default OF 1.6-ext interDyMFoam damBreakWithObstacle tutorial crashes
Arne Stahlmann
Arnoldinho is on a distinguished road
Hi all,
after recently switching from OF 1.7.x to 1.6-ext, I'm now struggling with some problems running the tutorials for the interDyMFoam solver. At least the damBreakWithObstacle tutorial crashes for OF-1.6-ext in serial and parallel mode, whereas everything runs fine in OF 1.7.x. All bug fixes (at least for the master branch) are included in my current OF version.
Coming to the errors messages:
1. In dambreakWithObstacle (running via Allrun), I get (in single and parallel mode)
Selected 16 cells for refinement out of 95858.
From function void polyMesh::initMesh()
in file meshes/polyMesh/polyMeshInitMesh.C at line 82
Truncating neighbour list at 295942 for backward compatibility
Refined from 95858 to 95970 cells.
Selected 6 split points out of a possible 7672.
Segmentation fault
The problem seem to be the split points, as until the crash appears, always 0 split points have been selected.
2. Running the floatingObject tutorial, I get
--> FOAM Warning :
From function void setFieldType(const fvMesh& mesh, const labelList& selectedCells,Istream& fieldValueStream)
in file setFields.C at line 102
Field alpha1 not found
Why has the folder structure in 0 (0.org, setSubset) been re-organised in comparison to 1.7.x?
Arnoldinho is offline   Reply With Quote
Old   May 25, 2011, 10:34
Arne Stahlmann
Put it here https://sourceforge.net/apps/mantisbt/openfoam-extend.
Old   May 25, 2011, 12:31
Martin Beaudoin
mbeaudoin will become famous soon enough
You can take a look at recent runs of the OpenFOAM-1.6-ext test harness:
http://openfoam-extend.sourceforge.n...ate=2011-05-24
One can see that this specific tutorial is running fine under OpenFOAM-1.6-ext, using various OS flavors, including Ubuntu 10.10.
Please take a look at my comments on the Bug tracking system for OpenFOAM-1.6-ext.
Martin
Originally Posted by Arnoldinho View Post
mbeaudoin is offline   Reply With Quote
Old   May 25, 2011, 12:44
Sandeep Menon
deepsterblue will become famous soon enough
Martin,
Doesn't the test-harness run each tutorial for only one time-step?
Sandeep Menon
University of Massachusetts Amherst
https://github.com/smenon
deepsterblue is offline   Reply With Quote
Old   May 25, 2011, 12:50
Martin Beaudoin
Yup, your are right.
Running this tutorial for more than one time step on my system, I can reproduce the problem as well, at t=0.0280313, with a nice Segmentation fault.
So there is indeed a problem with this tutorial.
Martin
Originally Posted by deepsterblue View Post
Martin,
Old   April 3, 2013, 17:13
Aleksey Rukhlenko
Aleksey_R is on a distinguished road
Send a message via ICQ to Aleksey_R
Dear colleagues,
is there any update on this issue?
Best regards,
Aleksey.
P.S. All my trials to use dynamicRefineFvMesh possibilities in OF-1.6-ext failed due to segmentation fault on early steps of calculation.
Aleksey_R is offline   Reply With Quote
interDyMFoam crashes with Segmentation Fault rassilon OpenFOAM 5 January 5, 2011 19:22
interDyMFoam mass conservation issues - dam break tutorial kmooney OpenFOAM 5 June 1, 2010 14:23
TwoPhaseEulerFoam bed tutorial case crashes in 1.6. Stable in 1.5 hemph OpenFOAM Bugs 2 February 17, 2010 08:10
TwoPhaseEulerFoam bed tutorial case stable in 1.5, crashes in 1.6 hemph OpenFOAM 3 December 5, 2009 04:19
movingConeTopo tutorial from 1.5-dev crashes with Floating Point Exception jaswi OpenFOAM Running, Solving & CFD 2 April 26, 2009 10:21
