Home > Forums > Software User Forums > OpenFOAM > OpenFOAM Bugs
Algeabraic operation with #calc
Old   November 24, 2013, 13:09
Default Algeabraic operation with #calc
Canakkale Dardanelspor
HakikiCanakkaleli is on a distinguished road
Hi
== 1 ==
#calc, used in blockMeshDict context, seems to give different answers for the following:
== 2 ==
b 4;
c 3;
d 10;
// First one-line calculation
a #calc "b / d * c";
// Second one-line calculation
a #calc "(b * c) / d";
== 3 ==
I could not find any reasoning behind the difference; therefore, I thought it would be better to consider it as a small bug.
HakikiCanakkaleli is offline   Reply With Quote
Old   November 25, 2013, 03:54
akidess's Avatar
Anton Kidess
akidess will become famous soon enough
You don't include the answers you get in your post, which would help debugging a lot. I'm guessing integer division is to blame.
*On twitter @akidTwit
*Spend as much time formulating your questions as you expect people to spend on their answer.
akidess is offline   Reply With Quote
Old   November 25, 2013, 04:34
haakon will become famous soon enough
You could try to define b, c and d as scalars:
b 4.0;
c 3.0;
d 10.0;
and follow up with a detailed description of the input files and the error if it does not solve your problem.
haakon is offline   Reply With Quote
complex number operation in udf? hongxiao FLUENT 5 June 14, 2017 14:11
operation pressure and pressure outlet BC Lilly FLUENT 4 May 8, 2013 09:57
How to define the edge after Boolean Operation Jeffrey FLUENT 0 May 14, 2007 06:51
Initalization fails with Operation Pressure = 0 Pa Tobias FLUENT 3 October 31, 2005 09:02
Rotation flow calc. II. Andy Christian Main CFD Forum 2 April 10, 2003 04:06
