Home > Forums > Software User Forums > OpenFOAM > OpenFOAM Bugs
aachenBomb with sprayFOAM not working
Like Tree1Likes
  • 1 Post By mturcios777
Old   February 9, 2012, 06:01
Default aachenBomb with sprayFOAM not working
Jens Keller
jenzkeller is on a distinguished road
why is the aachenBomb tutorial with the solver sprayFOAM in OpenFOAM 2.1.x not working? I have updated my Foam version today!
At first OpenFOAM tells me that:
keyword massFlowRate is undefined in dictionary run/tutorials/lagrangian/sprayFoam/aachenBomb/constant/sprayCloudProperties::subModels::coneNozzleInjectionCoeffs
after adding
massFlowRate 1e-3;
to the dictionary i got the next error:
#0  Foam::error::printStack(Foam::Ostream&) in "/home/XXX/OpenFOAM/OpenFOAM-2.1.x/platforms/linux64GccDPOpt/lib/libOpenFOAM.so"
#1  Foam::sigSegv::sigHandler(int) in "/home/XXX/OpenFOAM/OpenFOAM-2.1.x/platforms/linux64GccDPOpt/lib/libOpenFOAM.so"
#2   in "/lib64/libc.so.6"
#3  Foam::cachedRandom::scalar01() in "/home/XXX/OpenFOAM/OpenFOAM-2.1.x/platforms/linux64GccDPOpt/lib/libOpenFOAM.so"
#4  Foam::ConeNozzleInjection<Foam::KinematicCloud<Foam::Cloud<Foam::SprayParcel<Foam::ReactingParcel<Foam::ThermoParcel<Foam::KinematicParcel<Foam::particle> > > > > > >::ConeNozzleInjection(Foam::dictionary const&, Foam::KinematicCloud<Foam::Cloud<Foam::SprayParcel<Foam::ReactingParcel<Foam::ThermoParcel<Foam::KinematicParcel<Foam::particle> > > > > >&) in "/home/XXX/OpenFOAM/OpenFOAM-2.1.x/platforms/linux64GccDPOpt/lib/liblagrangianSpray.so"
#5  Foam::InjectionModel<Foam::KinematicCloud<Foam::Cloud<Foam::SprayParcel<Foam::ReactingParcel<Foam::ThermoParcel<Foam::KinematicParcel<Foam::particle> > > > > > >::adddictionaryConstructorToTable<Foam::ConeNozzleInjection<Foam::KinematicCloud<Foam::Cloud<Foam::SprayParcel<Foam::ReactingParcel<Foam::ThermoParcel<Foam::KinematicParcel<Foam::particle> > > > > > > >::New(Foam::dictionary const&, Foam::KinematicCloud<Foam::Cloud<Foam::SprayParcel<Foam::ReactingParcel<Foam::ThermoParcel<Foam::KinematicParcel<Foam::particle> > > > > >&) in "/home/XXX/OpenFOAM/OpenFOAM-2.1.x/platforms/linux64GccDPOpt/lib/liblagrangianSpray.so"
So whats happening?
jenzkeller is offline   Reply With Quote
Old   February 9, 2012, 12:58
Retired Super Moderator
Bruno Santos
Greetings Jens,
The git version isn't always very stable. They made some changes to the git version, which affects that tutorial, namely this one: https://github.com/OpenFOAM/OpenFOAM...9e9c33a0fbe341
I think the related change is being tracked here: http://www.openfoam.com/mantisbt/view.php?id=407 - you can properly complain there
Best regards,
Bruno
Old   February 9, 2012, 13:30
mturcios777's Avatar
Marco A. Turcios
mturcios777 will become famous soon enough
I'm the one who has reported on the issue. I guess the tutorial case hasn't been updated to reflect the changes. I've uploaded a sprayCloudProperties that works with the current version of sprayFoam (tested this morning), just copy it over and remove the extension.
There are a lot of new entries that I'm still figuring out. Mainly I'd like to know what the constantProperties part of the file defines for the parcels. Still looking for answers, will post when I find anything of note.
EDIT: I'd performed some limited testing and it appears that rho0,T0 and Cp0 are the properties of parcels as they are introduced into the domain. As the file currently stands, the r0, cp0 are for water at atmospheric pressure and T0. The dieselSpray class used to pull the properties from whatever liquid you were injecting at the stated conditions automatically. I'm still figuring out what properties get used where, as I think it would be better to obtain properties from liquidProperties.
mturcios777 is offline   Reply With Quote
Old   February 11, 2012, 05:05
niklas's Avatar
Niklas Nordin
niklas will become famous soon enoughniklas will become famous soon enough
i dont understand why you need to define massFlowRate, it looks like
you have some old files still hanging around.
If you do you can get some weird effect.
Have you done clean in lagrangian/intermediate and then wake libso?
still, I think you need to give it at keyword before the value.
Like
massFlowRate constant 1.0;
niklas is offline   Reply With Quote
Old   February 13, 2012, 04:54
Jens Keller
Like
thx
it works now!
Old   May 15, 2014, 03:16
raviteja
sraviteja is on a distinguished road
Could you please tell tell me ,how to specify the injection pressure in sprayfoam aachen box example. There was an option in dieselFoam, But i dont find it in sprayfoam.
sraviteja is offline   Reply With Quote
Old   June 5, 2014, 15:07
yes
ENKIME is on a distinguished road
Dear Marco
I read a post from you days ago about the changes that appear in sprayFoam and I have the same question that Raviteja, I need to change the injection pressure, where is that value or how can I add to the spray properties?.
I use the OpenFoam wiki about injection pressure but they make reference about the dieselFoam solver, where you can easily change the injection pressure, and add a line with the scalar value as set in the coneNozzleinjector.C.
duration 1.2e-3;
position ( 0 0.0795 0 );
direction ( 0 -1 0 );
//..Pressure added
injectionPressure 800.0e+5;
Really running out of ideas.
Any advice will be very gratefully.
Thanks a lot
Kind regards
ENKIME is offline   Reply With Quote
Old   June 6, 2014, 14:18
Marco A. Turcios
You should use the coneNozzleInjection injector model, which should give you access to a parameter called Pinj which is the injection pressure.
omid20110 likes this.
Old   June 8, 2014, 19:01
yes
Thanks a lot my friend I'm also change to pressureDrivenvelocity
King regards
sprayfoam
DPM parallel is not working but serial is working johnwinter FLUENT 1 March 27, 2012 03:01
ICEM working directory setting Bogesz CFX 2 October 8, 2008 08:45
Working Principle of Micro-Oven aero Siemens 2 January 31, 2007 06:00
Help required on working of Micro-oven aero CFX 4 January 19, 2007 09:21
Help required on working of Woven aero FLUENT 0 January 16, 2007 07:25
