Home > Forums > Software User Forums > OpenFOAM > OpenFOAM Bugs
thermalBaffle1D showing bad behavior
Like Tree1Likes
  • 1 Post By wyldckat
Old   May 17, 2015, 09:20
Question thermalBaffle1D showing bad behavior
Alex
zfaraday will become famous soon enough
Dear foamers,
Lately I have been trying to work with cylindrical baffles in a multiregion case. The solver I'm working with is chtMultiRegionSImpleFoam and I'm working with OpenFOAM 2.3.x. The case I'm currently working on aims to test the thermal behavior of the elements inside a furnace in vacuum conditions. As a consequence, I'm only interested in computing radiative and conductive heat fluxes since convection can be neglected. For this purpose, I set the thermal conductivity of the fluid region close to 0 by adjusting properly tha values of cp or Pr number in the "constant/fluidRegion/thermophysicalProperties" (I use constant transport and thermophysical properties). Furthermore, I activated the frozenFlow option in fvSolution file.
One of the regions that make up the whole system are a set of cylindrical heat shields that prevent from heat losses. Since these components have a small thickness compared to their length I decided to create them as baffles using the utility createBaffles and the BC named thermalBaffle1D, that develops the heat conduction equation in 1D and allows to include Qr in the balance as follows
Q_r + \frac{k_{w}}{\delta}(T_{i} - T_{p}) = \frac{k_{s}}{\delta_s} (T_p - nbrT_p)
being
k_w the thermal conductivity of the fluid near the patch (kappaEff)
\delta the distance between the center of the patch face to the center of the cell (\frac{1}{deltaCoeffs})
k_s the thermal conductivity of the the baffle
\delta_s the baffle thickness
In order to compute the mentioned balance, and according to the source code, the boundary condition (thermalBaffle1D) uses
f = \frac{alpha}{alpha+myKDelta}
refValue = \frac{KDeltaSolid * nbrT_p}{alpha}
refGrad = 0
with
myKDelta= \frac{k_w}{\delta}
KDeltaSolid= \frac{k_s}{\delta_s}
alpha=KDeltaSolid - \frac{Qr}{T_p}
On the paper it looked fantastic and I thought that I was going to get nice values by using this BC with the heat shields created as baffles. However, it wasn't that cool...
In my case, the balance at the patch was a little simpler since I don't have to compute the convection term (OpenFOAM does it anyway although tha values of convection heat transfer are small depending on the value of cp or Pr I choose in the thermophysicalProperties file). Bellow the equation without the convection term is shown.
Q_r  = \frac{k_{s}}{\delta_s} (T_p - nbrT_p)
The fact that k_w is close to 0 implies that
k_w=0 ===> myKDelta=0 ===> f=1
So far, it seems that the mentioned BC must work properly for my case. However, it was not like that...
After some tests I found out that the fact of setting low values of cp (or hign values of Pr instead) in the "constant/fluidRegion/thermophysicalProperties" file has a weird influence on the thermal distribution on the baffles once the solver has converged. More exactly, what is happening is that the lower value the cp (or higher value the Pr) has, the variation of the baffle temperature is smaller from the initial value. For instance, if I set a value of cp (for the air) of 1e-5 and an initial value for the temperature in the baffle surface of 500 K, once the solver has converged the temperature in the baffles is almost uniform of 500 K. If I increase the value of cp to, say, 1e-2, the final value of the baffle temperature shows a little more variation, say, it's in a range between 500.1 and 500.3 K. However, if I use a normal value for the cp of the air (1000), the baffle's temperature distribution looks quite physical and its values go from 492 to 548 K. Attached you can see a quarter of the cylindrical shield and its temperature distribution with a value of the cp for the air of 1000.
I cannot understand why the value of k_w makes that big difference over the value of the temperatures on the baffles, whereas the effect of the radiative heat flux has no influence when k_w has a very low value, because, according to the source code, it shouldn't be like that.
Another strange thing I noticed is that the value of the relaxation factor for the Qr is not taken inton account or, at least, is not shown properly. In this other post you can see how I define my baffles in the createBafflesDict file.
If I give a value different from 0 to the relaxation factor in the createBafflesDict file, say, a value of 0.5 as you can see below
"./0.org/include/1DBaffle/1DTemperatureMasterBafflePatches_shield"
T
    type   compressible::thermalBaffle1D<hConstSolidThermoPhysics>;
    thickness       uniform 0.002;  // thickness [m]
    Qr              Qr;
    relaxation      0.5;
    Qs              uniform 0;    // heat flux [W/m2]
    # include "1DbaffleSolidThermo_shield"
    value               uniform 500;
This is how it looks the "processor0/0/air/T" file once the baffle is created:
shieldBaffle1D_1_up_master
        refValue        uniform 500;
        refGradient     uniform 0;
        valueFraction   uniform 0;
        value           uniform 500;
        sampleMode      nearestPatchFace;
        sampleRegion    air;
        samplePatch     shieldBaffle1D_1_up_slave;
        coupleGroup     shieldBaffle1D_1_up;
        Qs              uniform 0;
        specie
            nMoles          1;
            molWeight       20;
        equationOfState
            rho             7930;
        thermodynamics
            Cp              460;
            Hf              0;
        transport
            kappa           21;
        QrPrevious      uniform 0;
        Qr              Qr;
        QrRelaxation    0;
        value           uniform 500;
        sampleRegion    air;
        samplePatch     shieldBaffle1D_1_up_master;
        Qr              Qr;
        QrRelaxation    0;
The same occurs in other times, not only in 0 time. Thus, either the relaxation factor is always 0 no matter what value you want to use, or it uses the value you set although it keeps showing a 0 somehow... Furthermore, I have tested createBaffles utility both in parallel and serial mode obtaining strange results.
  • createBaffles in serial and solved in parallel:
    • processor0/*/air/T: QrRelaxation=0
    • 0/air/T (after reconstruction): QrRelaxation=0.5
    • */air/T (after reconstruction): QrRelaxation=0
  • createBaffles in parallel, solved in parallel:
  • createBaffles in serial, solved in serial:
    • */air/T: QrRelaxation=0
At this stage, I don't have a clue where the problem is but I would like to know if I can do something in order to get good results using these BC in my case (without convection). Maybe both problems mentioned above are related, no idea...
Should I report this issue in the bug tracker? Any kind of help is much apprecaited.
Best regards,
Alex
PS: I apologize for the post's length...
Web site where I present my Master's Thesis: foamingtime.wordpress.com
The case I talk about in this site was solved with chtMultiRegionSimpleFoam solver and involves radiation. Some basic tutorials are also resolved step by step in the web. If you are interested in these matters, you are invited to come in!
Last edited by zfaraday; May 18, 2015 at 07:42. Reason: paths in the last list corrected. Image correctly attached
zfaraday is offline   Reply With Quote
Old   May 17, 2015, 14:27
Retired Super Moderator
Bruno Santos
Greetings Alex,
You did very well in providing as much information as possible! Although, a few details are missing:
  1. A test case would come in handy to test what you're seeing.
  2. I think you mentioned an attached image... and I can't see any.
The first problem I can spot is this: Did you check what values "alpha" has got? Namely in the equation for "f".
The second problem is regarding "createBafflesDict", because this line:
relaxation      0.5;
will not be automatically interpreted to this:
QrRelaxation    0;
the names are different, therefore they are not the same.
The third problem... is just a suspicion. If you are getting one situation where you get:
QrRelaxation    0.5;
and all others are "0.0", then you possibly are not setting up the case in the same exact way for all situations. In other words, you might not be relying on scripts to set-up the case for you and perhaps you're manually editing some files?
Like I wrote above, having a good test case would make it easier to diagnose the problem. And I hope you're using "Allrun" scripts to help run the case.
In addition, I strongly suggest you first try solving a 2D problem case, so that you can do the tests faster and the mathematics are easier to do manually, in order to double check what might be going wrong.
And if there is a bug in createBaffles, then we definitely need a test case, in order to isolate the problem.
Best regards,
Bruno
Old   May 18, 2015, 08:19
Smile
Alex
Thanks for your quick answer Bruno, your insight is much appreciated.
Originally Posted by wyldckat View Post
Greetings Alex,
I will work in a simple test case and upload it as soon as I can. Regarding the image attached, something happened and it wasn't uploaded properly. Now you can watch it.
How can I check the value of alpha? I only checked the value of "f", that relies on the value of k_w, and the smaller this value is, the closer to 1 "f" gets to. For a value of cp of 1e-5 "f" is 1.
relaxation      0.5;
QrRelaxation    0;
Well, I think you are wrong here, or the code of the thermalBaffle1D is otherwise. If you take a look at the source code, you can see that in the line 105 of the file thermalBaffle1DFvPatchScalarField.C it is stated:
    QrRelaxation_(dict.lookupOrDefault<scalar>("relaxation", 0)),
so it looks for a field named relaxation, not QrRelaxation. Besides that, in the usage's example in the header file a field named relaxation is also used.
QrRelaxation    0.5;
I use Allrun scripts to set up the whole cases I work in, so I'm not manually editing any file. The baffle setup I used in my case is based on the setup used in the $FOAM_TUTORIALS/heatTransfer/buoyantSimpleFoam/circuitBoardCooling tutorial, since this is the only tutorial where thermalBaffle1D BC is used. Actually, I just tested the QrRelaxation issue in this tutorial case and it writes out a value of 0.5 in the 0 time but it doesn't in further times...
Best regards,
Bruno
I don't think the problem is in the createBaffles utility, but in thermalBaffle1D BC. As soon as I have the test case I will upload it.
Many thanks again for your advices.
Best regards,
Alex
Old   May 18, 2015, 14:42
Bruno Santos
Greetings Alex,
Earlier today, as soon as I saw that you had replied to my post and you stated that I was wrong, I remembered that yesterday I didn't manage to take a look into the source code of the BC. Since you provided the link in your post, I saw the code and the bug regarding the "relaxation" keyword and reported it here: http://www.openfoam.org/mantisbt/view.php?id=1696
The fix was up less than an hour later and is shown here: https://github.com/OpenFOAM/OpenFOAM...f72ad2fb034bf5
As for showing the "alpha" value, find the following piece of code in this boundary condition:
        scalarField KDeltaSolid(kappas/baffleThickness());
        scalarField alpha(KDeltaSolid - Qr/Tp);
Now append the following lines after the last line:
Info << "alpha: " << alpha << endl;
Info << "KDeltaSolid: " << KDeltaSolid << endl;
Info << "Qr: " << Qr << endl;
Info << "Tp: " << Tp << endl;
Then compile the library where the boundary condition is located... if I'm not mistaken:
wmake libso $FOAM_SRC/turbulenceModels/compressible/turbulenceModel
Then run the solver, to see what values it gives you on screen or in a log file.
My suspicion is that the "alpha" values you're getting are very small and that something like the following might be happening:
0.0001/(0.0001 + 0.01)
Best regards,
Bruno
zfaraday likes this.
Old   May 18, 2015, 16:12
Default test case
Alex
Thanks Bruno for reporting the bug! I just saw that it had been solved just some minutes before you posted your last post. However, I don't know if it solves my main problem, I will check it out soon!
My main problem was that when I deactivated the effect of convection (by setting a low value of Cp in the "air/thermophysicalProperties" file) in order to compute only radiation and conduction heat transfer, the thermal distribution on the baffle was not realistic since it remained constant (or almost constant) with the same value as the initial one. With this post I attach a simple test case where this effect can be noticed. This case is based on the original tutorial case "circuitBoardCooling", the only differences are:
  • one of the two baffles has been modified to be both of the same type (thermalBaffle1D). The one that has been modified is generating a superficial heat flux while the other one is not.
  • pressure has been diminished to 1e-2.
  • the effect of the radiation has been added (fvDOM)
  • the system has been closed so that no air flows through the patches
  • all external walls are now of type "externalWallHeatFluxTemperature", not taking into account Qr (1)
It's not exactly the same case I was struggling with in the first post of this thread because the other one was run with chtMultiRegionSimpleFoam solver, while this one is solved with buoyantSimpleFoam. Even so, I guess that the solver for the fluids in chtMultiRegion solvers does the same as buoyantSimpleFoam... I haven't checked the source code. Nonetheless, the effect I want to show is the same in both cases: when the thermal conductivity of the fluid region is diminished by giving a low value to the Cp, the baffle temperature doesn't show physical values (the lower the Cp is, the less changes the temperature from the initial value).
I also want to thank you for the good advice you gave me. I will add that piece of code to the BC source code in order to check where the error may be.
Best regards,
Alex
PS. Btw, I would like to understand why a relaxation factor for Qr is needed in this BC and it's not in other BC's (e.g. in externalWallHeatFluxTemperature among others)
__________________________________________________ ____________
(1) I have to dismiss the effect of Qr at the boundaries because when I try to take it into account the solver always crashes after some iterations. I found it out some time ago in a case solved with chtMultiRegionSimpleFoam. Maybe it is another bug to be reported...
Old   May 22, 2015, 08:02
Alex
After some tests, it seems to solve the problem!
Thanks Bruno for the report!
Best regards,
Alex
Old   October 1, 2016, 16:05
Zeppo's Avatar
Sergei
Zeppo will become famous soon enough
You can specify the relax factor for Qr in system/fvSolution dictionary
//- system/fvSolution
relaxationFactors
    fields
         Qr       0.1;
The relaxation is performed just after new values for Qr field are computed. For example, using viewFactor radiation model it is done in viewFactor::calculate() function:
//-src/thermophysicalModels/radiation/radiationModels/viewFactor/viewFactor.C
void Foam::radiation::viewFactor::calculate()
    // Relax Qr if necessary
    Qr_.relax();
From my experience I can conclude that relaxating Qr is going to stabilize solution a lot. Try it.
Zeppo is offline   Reply With Quote
chtmultiregionsimplefoam, convection, createbaffles, radiation
Bad pressure distribution in pump oringo FLUENT 2 March 2, 2013 10:38
[ANSYS Meshing] Very thin plate (0.1mm) ICEM CFD bad meshing msormania ANSYS Meshing & Geometry 1 April 30, 2012 07:45
Allwmake path error kiski OpenFOAM Installation 20 March 22, 2012 12:45
Bad OpenGL Performance with FIRE GL2 using GAMBIT Volker Pawlik FLUENT 1 December 1, 2003 12:38
Problems of Duns Codes! Martin J Main CFD Forum 8 August 14, 2003 23:19
