Home > Forums > Software User Forums > OpenFOAM > OpenFOAM Bugs
plateHole in solidMechanics/elasticSolidFoam fails checkMesh in Opt but runs in Debug
Old   November 10, 2015, 00:54
Default plateHole in solidMechanics/elasticSolidFoam fails checkMesh in Opt but runs in Debug
Ripudaman Manchanda
ripudaman is on a distinguished road
I am using foam-extend-3.2 on Mac OS 10.10
The plateHole case in solidMechanics/elasticSolidFoam gives a floating point error when I try to run the case. The mesh looks okay in paraview. However, when I run checkMesh on the mesh, it gives the same Floating Point Error.
These errors go away in debug mode and the case runs fine.
This also happens in the slidingFrictionBall case in the same elasticSolidFoam solver.
I pulled the latest version of the master branch and compiled it to test this out again but to no avail.
Please help.
Thank you.
Ripu
P.S. This has been posted as a bug on the foam-extend bug tracker on source forge
ripudaman is offline   Reply With Quote
Old   November 10, 2015, 11:46
Default more information
Ripudaman Manchanda
I dug deeper and found that the error occurs in the creation of the mesh object in createNamePolyMesh.H (lines 21-30)
    Foam::polyMesh mesh
        Foam::IOobject
            regionName,
            runTime.timeName(),
            runTime,
            Foam::IOobject::MUST_READ
This part of the code is the same as the code in fe31. Thus I believe the numerous changes made in polyMesh are the root of the problem. I compared the fe31 polyMesh and the fe32 polyMesh directories but I was very quickly overwhelmed. However, I noticed that the constructor declaration and definition both had no changes.
I need help with this.
Also, is there any other way of getting an error stack for this? Since the code runs fine in Debug mode... I do not know how to proceed and get the source of the error.
Thank you.
Ripu
Old   November 12, 2015, 12:26
Default Works in Linux and Windows
Ripudaman Manchanda
So this actually seems like a problem inherent to the Mac OS. It occurs both in Yosemite (10.10) as well as El Capitan (10.11). The plateHole case does work in Win 7 and Ubuntu 14.04.
Here are my Mac etc/bashrc file changes:
# WM_MPLIB = SYSTEMOPENMPI | OPENMPI | MPICH | MPICH-GM | HPMPI | GAMMA | MPI | QSMPI | MVAPICH2
: ${WM_MPLIB:=MACPORTOPENMPI}; export WM_MPLIB
# : ${WM_MPLIB:=OPENMPI}; export WM_MPLIB
# Compiler: set to Gcc or Icc (for Intel's icc)
: ${WM_COMPILER:=Gcc46}; export WM_COMPILER
# : ${WM_COMPILER:=Gcc}; export WM_COMPILER
#: ${WM_COMPILER:=Icc}; export WM_COMPILER
Kindly point out any issues that you may feel are causing the strange behavior with the mesh.
Old   December 1, 2015, 18:08
Default Change the GCC version to fix this....
Ripudaman Manchanda
I was able to solve the issue by changing the GCC version
GCC48 on pre ElCapitan and GCC49 on ElCapitan
checkmesh, foam-extend-3.2, platehole
GGI and Topological changes - checkMesh fails strakakl OpenFOAM Programming & Development 4 November 10, 2019 05:48
Problem in Implementing a non-linear SGS model huangxianbei OpenFOAM Programming & Development 30 September 20, 2015 13:26
[OpenFOAM] could not open file .vtk in paraview ali_atrian ParaView 8 August 27, 2014 10:31
[Other] CheckMesh fails when cyclic boundaries are defined - OF 2.2.0 caduqued OpenFOAM Meshing & Mesh Conversion 2 May 21, 2013 18:31
Compiling checkMesh fails kjetil OpenFOAM Installation 1 February 8, 2010 11:05
